Vfr A Little Bit Higher
18 posts Started 21 Dec 2008 Last recovered post 21 Dec 2008 Wayback Machine snapshot 23 Dec 2008
Is there someone who allready made the vfr a little bit higher with kind of dogbones or something else?
When a drive mijn VFR from 1998 very hard in de twisties, my pegs and even the exhaust touches the tarmac. My preload is allready for duo (highest). Is it a solution to make him higher? How many mm? Does it changes the geometry? is it good for the stability on high speeding?
Or a new rear shock from hyperpro or wilbers is better?
So, best solution for more groundclearance??
avoiding things like this:
(IMG:http://i36.tinypic.com/2j299c0.jpg)
Learning to hang off may improve your ground clearance. And it's good for stability as well. There should be a thread or two about it somewhere here...
Hang off is allready in use...kweedown aswel
what are your SAG measurements? yes, you adusted preload, but we still need to know SAG to help. i adjusted mine to max and was at 55mm in rear and 35 in front!! way too much. new springs, rebuild and now its 22mm/25mm and she is a new bike!
Hi and I'm glad your enjoying leaning over enough to drag parts off in the twisties! (IMG:style_emoticons/default/biggrin.gif)
How much do you weight? Maybe stiffer springs are needed? (IMG:style_emoticons/default/blush.gif)
When i had my R6s I went from a 120/60/17 in the front to a 120/70/17 and had to shim the rear to keep the same quick steering.
Between the upper shock mount and where it bolts into the frame I put 2 2MM high grade galvonized washers to raise the rear some.
That will give you more clearance but keep in mind that your steering is going to speed up a bit.
You need a new shock. Correct springs will help, but what you need is more compression valving. You could increase your ride height and it would help a bit. If you are already hanging off you are just putting to much cornering force into the garbage Honda shock that is designed for touring and a low production cost.
I've seen on Ebay these wedges that bolt somewhere around the rear shock thats supposed to raise the rear of the bike, change the weight distribution, etc.... I dunno if it would help but you could check them out. I think they are around 45 dollars. Do a search on Ebay for vfr 800
I think, I am now at about 30mm raised in the rear, and have the front raised about 5mm.
I have the high end Ohlins shock in the rear with easily adjustable ride height, so I just crank it up a turn or two in the rear every time I go for a ride lately. The shock is sprung and valved for my weight and style, and my front end is sprung and valved likewise. I have also removed my centerstand. Since adding ride height and a proper shock, I have a lot less wear on my header and fairings.
So far with +30 or so mm in the rear I have not noticed any bad manners that you would expect by raising to this degree, which I have been watching out for. The bike is put away for the season, but I will continue raising the rear end next year to the point it starts to exhibit bad manners and report back my results.
ETA: hehe, my header pipe is crushed in and worn nearly though at that spot you took a picture
My weight is 80 KG, my rebound high. I haven't changed something else on the front.
In the netherlands (country next to mine), they build hyperpro and I really want those new shocks. But will it change a lot?
Normally on short twistie roads there is nothing that touches the ground. But when i ride the corners before or after and exit on the highway (In belgium you have very good �270-corners) on a speed of 115km/h, the pipes somethimes kisses the ground. Certenly with two, I have to slow down for about 15km/h.
So, raising for about 25mm at the back, it's fine?!
(IMG:https://www.euromotoaz.com/store/images/products/1810.jpg)
(IMG:https://www.euromotoaz.com/store/images/products/1309.jpg)
VFooR, Dec 22 2008, 04:54 AMMy weight is 80 KG, my rebound high. I haven't changed something else on the front.
CHECK YOUR SAG FIRST. You have a 98 bike. after setting SAG, you i would look at rebuilding/replacing your shock and changed oil/spring up front. yes, you can raise rear and drop front, but jeremy has his forks and shocks set up correctly FIRST. you can raise and lower all day, but if your suspension is rolling around like a cadillac, it won't help you much...
VFooR, Dec 22 2008, 03:54 AMMy weight is 80 KG, my rebound high. I haven't changed something else on the front.
Your weight isn't too bad as I think the bike is designed for a 160 lb rider, but with very low end pieces.
If you have the money to spend on good aftermarket suspension pieces then that is the best route to go, but I sure would NOT spend big $ on a shock that did Not offer ride height adjustment like the Hyperpro pictured above!
If you don't have extra cash for all the high end pieces, then you could just buy the correct springs, shim the rear shock and run another 10cc's of oil in the forks to start. (IMG:style_emoticons/default/cool.gif)
Baileyrock, Dec 22 2008, 10:34 AM
It looks like it has a ride height adjustment at the bottom at the rod end and jam nut.
Yeah, what everybody else said.
1. Shim your shock. I made a quarter inch (6 mm) shim for the top of mine that fits over the top of shock bolt. Used a small rectanglular piece of quarter inch aluminum and cut it to fit.
2. Get a shock that is length adjustable. I run a Penske on mine. I have the rear of my '02 raised about 30 mm total and I dropped the front end so the top of fork cap is 10 mm above the upper triple clamp. I think that works out to a front end drop of about 5-6 mm over stock. To give you an idea of where you want to be when it's all said and done, if the bike winds up with the rear wheel touching the ground when the bike in on the center stand, you're pretty close to the correct ride height in the rear.
3. Make sure your rear spring is correct for your weight.
When the VFR is set up properly, it will haul butt without dragging parts.
Once you've done all of this if you're still dragging parts 2 up, get a skinny/smaller girlfriend/wife.
Pete
(IMG:http://i29.photobucket.com/albums/c293/jbachetti/Honda%20VFR/989793282_l.gif) (IMG:http://i29.photobucket.com/albums/c293/jbachetti/Honda%20VFR/989793282_l.gif) (IMG:http://i29.photobucket.com/albums/c293/jbachetti/Honda%20VFR/989793282_l.gif) (IMG:http://i29.photobucket.com/albums/c293/jbachetti/Honda%20VFR/989793282_l.gif) (IMG:http://i29.photobucket.com/albums/c293/jbachetti/Honda%20VFR/989793282_l.gif) (IMG:http://i29.photobucket.com/albums/c293/jbachetti/Honda%20VFR/989793282_l.gif)
(IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/ohmy.gif) (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/tongue.gif) (IMG:style_emoticons/default/wheel.gif)
Now this is funny! Try to stuff a 1983 into the corners, with a fat butt like mine. You will learn how to get your butt off the seat. (IMG:style_emoticons/default/biggrin.gif)
(IMG:http://www.vfrdiscussion.com/forum/uploads/1229609609/gallery_8868_2008_103724.jpg)
(IMG:http://www.vfrdiscussion.com/forum/uploads/1229609609/gallery_8868_2008_220953.jpg)
Stephen
Pete McCrary, Dec 22 2008, 11:17 PM2. Get a shock that is length adjustable. I run a Penske on mine. I have the rear of my '02 raised about 30 mm total and I dropped the front end so the top of fork cap is 10 mm above the upper triple clamp. I think that works out to a front end drop of about 5-6 mm over stock. To give you an idea of where you want to be when it's all said and done, if the bike winds up with the rear wheel touching the ground when the bike in on the center stand, you're pretty close to the correct ride height in the rear.
Pete
Pete, is that right? Fork cap 10mm above the triple? That's less than 1/2" and doesn't give your clip-ons much to grab onto - besides being a raise in the front end! (IMG:style_emoticons/default/huh.gif)
SEBSPEED, Dec 23 2008, 06:17 AM
Pete
Seb:
You're right - that doesn't sound like much. Maybe it's 50 mm - my brain is not the sharpest now days. I'll check it at home tonight and repost. Thank for catching my faux pas.
Pete
End of thread · 18 posts recovered Wayback Machine snapshot 23 Dec 2008
