O2 Sensor Drain Plug Size?
7 posts Started 29 Jan 2009 Last recovered post 30 May 2011 Wayback Machine snapshot 11 Jun 2011
I've installed a PCIII, did the resitor mod on, can someone tell me what size drain bolts I need to replace the o2 sensors and where to procure such bolts?
I just left the sensors in place and secured the wires out of the way.
That's what I've done, but I'd rather just pull them.
I know this is an old thread but does anyone know the bolt and pitch size for the O2 plugs on a 2000 VFR800Fi? When I look at drag specialties web site I am seeing 12mm x 1.25 and 18mm x 1.5...
Prob wont help much but most cars are 18mm and there are only a handful of companies that make the sensors
Posted Image on the 18mm. I just took the sensors to NAPA and showed 'em to the parts guy. Two plugs ran about $3. I put copper anti-seize on them in case the emissions police in my state ever start sniffing bikes and I need to get them out.
I stopped by most auto parts stores and asked for a 18mm x 1.5 and they all said "We don't carry that large of a bolt". Then when browsing the store I found the oil drain plugs and there they were. 18mm 1.5 and they work great. Much cheaper than others are charging for the ones marked "O2 Plug". Now if I can only find the copper gasket....
End of thread · 7 posts recovered Wayback Machine snapshot 11 Jun 2011
