[image: View Post]SEBSPEED, on Mar 7 2009, 04:10 PM, said:
[image: View Post]dutchinterceptor, on Mar 7 2009, 04:05 PM, said:
[image: View Post]1LuckyDude, on Mar 7 2009, 01:59 PM, said:
Next time around, go to NAPA and get a bottle of Ru-Glyde. You'll thank me later. It takes all the work out of spooning on new tires (removal also). Good lube is the key.
Yep...what he said. No-Mar brand snot works good too!
That's what she said... :goofy:
Oops, was that out loud?? :blink:
I just started changing my own tires last night, I have a Harbor Freight setup w/mojo blocks. Gotta do some mods on the mount bar real soon.
I used Windex for lube, might look into some other stuff in the next month or two, I already have neighbors wanting tires done! :mellow:
I worked for the local St. Joseph Yamaha shop many years ago and they had a Coats changer and I used it a lot. The
Coats 107156 Combo Tool is the best around. I tried the No-Mar mount/demount bar but just couldn't get it to work for me. You do need the protective plastic covers for the Coats bar, but I have enough to supply several people. :) Do yourself a favor and pitch the tool that comes with the HF and get a Coats. It makes changing the tires a real breeze, easy on and easy off. Best investment you'll ever make.
