Coolant?
19 posts Started 12 Mar 2009 Last recovered post 14 Mar 2009 Wayback Machine snapshot 10 Apr 2010
What kind of coolant comes from the factory in 6th gen VFRs?
And is it a mix of coolant and water or just straight coolant?
It's a mix, I've been using Prestone 50/50 premix when flushing mine in all my bikes - no issues so far.
It has to be free of something that's escaping me at the moment...
Hi; Just make sure the anti-freeze you choose is silicate-free...if not you could end up damaging your water pump seals....Remember SILICATE-FREE anti-freeze.
Jeffy
The prestone extended life orange stuff is good, meaning phosphate free. But I think it comes from the factory with the Honda coolant which is premixed if you get it from the dealer, iirc.
Except the Honda coolant is about 4 times more expensive!
Of Charge? :laugh:
Of course, only mix with distilled water.
Can't go wrong with this stuff.
http://www.flatout-motorsports.com/catalog/images/Water%20Wetter.JPG
unless the temperature drops below freezing...
Yeah
He is in Texas
and you are in the Netherlands now....
but there should be no more frost
should be...
:biggrin:
...and then you won't be riding anyway. Or would you? :biggrin:
Water wetter doesnt significantly change the boiling point of water, as does anti freeze.
Too many have had boil overs, come here complaining, and normally not running Real antifreeze antifreeze
Honda long life type 2 coolant. It is silicste, phosphate, and borate free. It also comes pre-mixed. Honda coolant for a honda bike, you cant go wrong.
:+1:
That is probably the best way to go...........although I just changed my coolant and used Engine Ice.
well, that's exactly the point... not riding, temp below 0�C, and a serious danger of engine or other damage due to the water in your cooling system freezing.
i'd have no problem running straight water (with a little water wetter) over the summer season (or in a track bike), but it needs to be swapped out for a proper coolant/anti-freeze mix if there's any risk of the temperature dropping off.
I can understand on a track bike, using the simpler products temporarily and changing frequently , because of track requirements.
I dont know why the average street rider would though
Who has done any significant real long term tests, say 100,000 mile on watter wetter and distilled only. I just dont buy the stuff as better than Antifreeze on longevity.
I know that real antifreezes have alot of properties in it, to keep your system clean and lubricated , that little 12 oz bottle of colored Glycol is not going to match the health of the internal assembles that real anitfreeze can.
End of thread · 19 posts recovered Wayback Machine snapshot 10 Apr 2010
