The extreme quiet of the stock exhaust on my new-to-me '96 was wiggin' me out , or adding to it.
HAD to do something about that!
Did a three part partial gut on the muffler.
I drilled the 3 welds out holding the end cap onto the can to get access to the internals.
1st stage work... results, near diddly-squat!
Here’s part two (see hole I sawed in the partition at the back end of the outlet pipe.) Made some improvement but not much:
Here’s step three. Cut rear of inner canister out and removed wrapped baffle outlet pipe.
She barks some now, even closed up... more so with the end cap off as in this pic to show work:
To close the can back up I rotated the end cap a few degrees from the drilled out welds, drilled & tapped and secured things with 3 stainless button heads.
I've used those fasteners on many mods over the years as they give a nice finished appearence... kinda' like high-end factory rivets.
I'm quite happy with the result, she sings pretty sweetly now... not overly loud, nice tonality.
Burbles along nicely trolling in traffic or doin' a gentle gallop up backroads.
Only lets out a bit of a rip if I twist it with resolve.
This method should work just as well on a 3rd gen, the cans themselves are identical if not mistaken... you'll be pleased with the music I'm certain!
Steve
