[image: View Post]VFR Capt.Bob, on Jun 28 2009, 05:26 PM, said:
[image: View Post]onedowneaster, on Jun 28 2009, 07:36 AM, said:
Hi F14SCOTT; I really like you wheels, two question, did you have to remove the orig. wheel bearings and install new ones after the powder coating?
if so what kind of bearings did you use? eddieI'm going to guess there are ways to mask the bearings from the bead blasting. The powder coat is very thick and you wouldn't want it in on any machined surfaces as it will have to be removed for the bearings to fit. Had my fork lowers done and had to clean out the axel slots to fit the axel back in.
Wheels look great! I'm tired of my black rims but they do hide brake dust well. :cool:
Actually, the bearings had to come out, because powder coating involves baking at 400 degrees. If one leaves the bearings in, the grease runs out of them when heated and mucks up the powder coat. I also imagine some of the sand blasting media would find its way into the bearings, no matter how well one taped them off, and that would kill them in short order. My shop replaced the pair of wheel bearings and the pair of dust seals with OEM Honda ones for $20 parts and .5 hours labor. The original spacer was fine.
The dust seals came right out with a screwdriver, but when I tried to pull the bearings out, my car bearing puller was too big and I couldn't get it to hook the edge. So, when I got to the bike shop, my guy showed me his method. He had an old electric stove in the corner. He put my wheel on it, suspended by a couple of 2x4 blocks, with the center right above a burner, which he turned on. About five minutes later, we heard a "clunk;" the bearing had fallen right out, along with the spacer. We flipped it over, and the other one fell out in one minute. Slick!
I also needed to remove the valve stems, but they were easy; just run a razor blade around the stem on the inboard side of the rim, then use a pair of pliers to rip the stem in half, then push the remaining part out the outboard side of the rim.
So, basically, I sent Kevin two solid circles of aluminum, and nothing more. He cleaned them, taped off the machined surfaces, sand blasted them, and powder coated them.
