http://www.vfrdiscus...creenshot&id=88
File Name: Cozye's Map PCIII NON-USBFile Submitter: Ryanme17
File Submitted: 30 Jul 2009
File Updated: 08 Dec 2009
File Category: Power Commander Maps
Here is a version of Cozye's map converted to run on a nonUSB PCIII.
Because Cozye's map has adjustments for every 250 RPM, and nonUSB PCIII only has ever 500 RPM, I made a few minor tweaks, usually only 1 % richer to try to get the same AFR between 500 RPM marks, but for the most part, it's just the same numbers copy-pasted over into the different format.
This is for the 2002-2005 models.
Click here to download this file
