Replacing my chain a week ago..
http://photos.linquist.net/photos/637792460_vGv6t-M.jpg
Cut the old one (pictured) off with an angle grinder... opened the new one to discover it had 120 links, decided to go out and spend the dough on the proper tools.. so now I have a nice RK chain tool.
http://photos.linquist.net/photos/645627055_GfNUh-L.jpg
I previously had a Puig touring windscreen. It started to crack (about 2" long when I removed it) starting right where the hex screws contact it. I also didn't like that it was "dark purple" (advertised as dark smoke, but in very bright light it had a purple tint). Got this ZG Double Bubble new from ZGOutlet.com for $70+shipping. Only ridden a few miles with it so far... no complaints. You can also see the 3M Scotchlite tape I put on my front forks since I removed the ugly reflectors...
http://photos.linquist.net/photos/645627315_8e3Qh-L.jpg
http://photos.linquist.net/photos/645627852_SXPQU-L.jpg
Two switches I installed.. so far, one turns on the USB power adapter I hard wired up for my ContourHD camera (which is currently back at the manufactuer because it was locking up, grr). The other switch doesn't do anything yet. It'll probably be for heated grips this winter. They're not waterproof switches, so lets see if they last through a rain... At least they're properly fused :).
http://photos.linquist.net/photos/645628547_wHAno-L.jpg
Fused switched power block...
http://photos.linquist.net/photos/645629022_nucS2-L.jpg
Wire running to the relay.. I still need to put wire loom around this one, I've put wire loom around all other wires I've installed (and with my Starcom1, PTT button, remote volume control, garage door opener, USB power, Garmin Zumo, etc.. there are lots!). I'm pretty anal about clean installs.
http://photos.linquist.net/photos/645628004_yNT4a-L.jpg
Voltage LED... will turn yellow or red if the voltage drops. Picked this up many years ago, finally got around to putting it on the bike.
http://photos.linquist.net/photos/645628106_nfn2c-L.jpg
Garage door button & Starcom volume control... you can also see the wire loom tucked away that holds my Kenwood radio audio cable for bike-to-bike comms (or bike to repeater, I'm an amateur radio operator... When in the mountains, in case of emergency, I usually have no problems finding a repeater with my 5W radio where there is no chance of cell coverage).
http://photos.linquist.net/photos/645628503_dYKqq-L.jpg
PCIII USB... Will probably be replaced with a PC V+autotune soon.
http://photos.linquist.net/photos/645627912_qjHZJ-L.jpg
Speedohealer.
http://photos.linquist.net/photos/645628911_2xALX-L.jpg
Here you can see the Starcom speaker/mic jacks for rider and passenger.
http://photos.linquist.net/photos/645629381_2nfSU-L.jpg
Sargent seat.. I've discovered that I'm not tall enough to really "take advantage" of better seats since I sit up against the tank. It didn't make a big difference. 30" Inseam.
http://photos.linquist.net/photos/645629101_SkmgN-L.jpg
I keep 4 CO2 cartridges for the Stop'n'Go tire plugger in the access door on the underside of the Sargent seat. The rest of the kit with the tire plugs is contained underneath my top case bracket.
Hope you enjoyed this tour :).
Speedohealer.
