6th Generation Cluth Master Cylinder Rebuild ?
2 posts Started 8 Oct 2009 Last recovered post 8 Oct 2009 Wayback Machine snapshot 8 Feb 2011
Has anyone rebuild there clutch master cylinder ? Mine is dripping from the nut cap underneath the lever on to the fairing was just wondering if it's tough to do or fairly easy job ? Any input would be appreciated.
I have a spare master cylinder from an 05 that I can get the parts from mine is an 06 and it's the polished metal the 05 is a black one other wise I would have just swapped it out.
I just ordered a piston set for the MC. It looks a pretty straightforward job: remove lever, pushrod, snap ring, piston assembly and replace in the reverse order.
End of thread · 2 posts recovered Wayback Machine snapshot 8 Feb 2011
