Power Commander Maps PC3 USB Staintune 1998-2001 5th gen European map
1 posts Started 10 Oct 2009 Last recovered post 10 Oct 2009 Wayback Machine snapshot 16 Jun 2012
[image: index.php?automodule=downloads&req=display&code=sst&id=96]
File Name: PC3 USB Staintune 1998-2001 5th gen European map
File Submitter: HispanicSlammer
File Submitted: 10 Oct 2009
File Category: Power Commander Maps
This is a direct transcription of the pc2 files posted at dynojet I combined the AAP tables and MP file tables from the original(map)file and converted it into a single (dmj) file table. The european staintune map is considerably leaner than the US version over the entire range of rpm and throttle postion.
I found it has good fuel economy and smooth power delivery for my 1998 vfr high mount staintune with silencer bud and K&N filter I used this map exclusivly when I had my old PC2. I get 40-42 mpg with this map riding 70-80 mph on the highways. I went back to this map after suffering 35mpg from the us version when I upgraded from the PC2 to a PC3 usb with no noticible difference in performance, I transcribed the old european pc2 map and made this file. The leaned out areas actually remove some flat spots from OEM fuel map hard coded in the ECM of the bike.
Click here to download this file
End of thread · 1 posts recovered Wayback Machine snapshot 16 Jun 2012
