In the wake of recent battery problems, I have done lots of reading of threads on VFRD about voltmeters, and have browsed the shops here to see what is available. To get and fit anything semi-decent, it looks like I'm going to have to part with more coin than I really want to.
How important would you deem a voltmeter to be? I've got a cheap multimeter of my own, and access to a couple of better ones. Most of my riding is commuting, so it's unlikely I'm going to get stranded anywhere. My bike now has a brand new battery (used a whole one time!), which is beefier than the OEM one (it's a factory-sealed AGM type, and 14Ah capacity). I have had two R/R failures (1990 VFR750 and 1998 VTR1000) and both took so long to die that I had plenty of warning, although both left me on the side of the road at least once. With the VTR I fitted a combination clock/stopwatch/voltmeter, and it helped me to diagnose an R/R failure while riding (which I then ignored and kept riding until the battery was so low that the ignition would no longer fire!)
I have no reason to suspect my current R/R of harbouring any malice towards me, as it checks out fine, and the 2001 VFR isn't renowned for charging system problems.
The trouble I have is that various battery monitoring devices are either too big (analog voltmeter), too simple (coloured LEDs) or too expensive, or too ugly, or not weatherproof (I ride in all weather) or many of the above.
Do I really need one?
