kaldek
CandyRedRC46
remove and blockoff pair valves and all associated hoses and hardware
these two are mainly just for weight loss though disabling the pair valves does give more accurate air/fuel ratios for who ever tunes your bike.
Interesting, I hadn't thought of that with regards to tuning.
also i would remove the snorkel and disable the flapper. the benifits are added sound a little horsepower and a little weight savings.
Not really sure if I agree with that - I've tested how the flapper works on the VTEC model and it's under load, not just low revs (in fact the airbox flapper is open all the time unless you and only closes if you are below 5,000rpm AND then whack the throttle open - I had a post on the forum here awhile back but it got lost in an upgrade). In essence - there is no possible way this mod can increase horsepower. The total weight saving must be 200 grams at most!
I will admit though that snorkel removal creates a meaty intake sound...
one thing that i would like to do to my bike but wouldnt feel comfortable on the street with is a thurn tail riser and possibly lowering the front end. this would give quicker turn in and handling.
maybe a 1 down and 2 or 3 up sprocket kit.
The geometry changes I'd be cool with, but the sprocket kit I don't think is worth it. She certainly wasn't lacking drive at Phillip Island yesterday, and on the main straight you wouldn't get any top-end speed!
also i would as you said scrap the staintunes for added cash and look into somesort of light weight custom shorty muffler, then ditch all the heat sheilding material in the tail section...
Man, she'd look wierd with no pipes under the seat!!
thanks veefer800canuck...
Another oldie but a goodie pulled from the dusty archives of the Big VFR List:
Quote:
-----Original Message-----
Sent: Monday, 29 March 1999 5:20 PM
To: vfr@cs.wisc.edu
Subject: 800 snorkel dyno test (mostly data)
Hello list ...
Had the opportunity to do a back to back dyno test on the VFR800. We'll let
the numbers tell the story.
Dynojet Model 150 Chassis Dynamometer
Eastside Harley Davidson, Bellevue, Washington
DYNORUN #1, baseline, 4th gear roll-on - 3-27-99, 3:17PM
DYNORUN #5, no snorkel, 4th gear roll-on - 3-27-99, 3:22PM
DYNORUN #1 DYNORUN #5
RPM SAE hp SAE hp
3500 28.3 28.8
4000 32.1 31.7
4500 35.4 35.4
5000 39.8 40.3
5500 45.2 46.1
6000 54.4 55.3
6500 62.6 63.2
7000 69.6 69.9
7500 75.6 75.5
8000 81.1 information not available
8500 86.6 87.1
9000 90.0 91.0
9500 91.6 92.7
10000 93.2 93.8
10500 92.9 94.2
11000 90.3 91.6
11500 88.8 89.6
Magnifying the resolution of the 500 rpms nearest the hp peak follows
10000 93.2 93.8
10100 93.4 94.1
10200 93.5 94.3
10300 93.6 94.6
10400 93.3 94.6
10500 92.9 94.2
Magnifying the resolution of the 1000 rpm range nearest torque peak follows
RPM SAE ft-lb SAE ft-lb
8100 53.4 53.3
8200 53.4 53.4
8300 53.6 53.6
8400 53.6 53.7
8500 53.5 53.8
8600 53.4 53.8
8700 53.2 53.7
8800 53.0 53.6
8900 52.8 53.4
9000 52.5 53.1
Testing conditions: 29.66 in.Hg. absolute barometric pressure, Vapor
pressure .44 in. hg., ambient air temperature 49.5 deg. F. Partly cloudy.
All stock '98VFR800FI, 3,273 miles.
Subjective comment: Noticeably louder intake noise. Doesn't sound like a
sewing machine anymore. Changes the character of the engine. Feels raw,
sharper edged. I will be leaving the snorkel out for now.
Wayne Chan, WMRRA/OMRRA #326
__________________
+ ZG ST, Heli's, Fender Eliminator, Throttlemeisser, Triangle Flip+Preload, BMC Filter. 200*Fan Switch, VTR Fan Blade
- Snorkel, Flapper, Velocity Stacks. Pair Valves, and Evap Canister.
Rounded off Entries to Throttle Bodies
Motad Header and Two Brothers Exhaust
Fully heat wrapped and sealed in high temp black
Power Commander 3 USB & O2 Eliminators
Custom Tune Done By AMR SUPERBIKES
CandyRedRC46 is online now Report Post Edit/Delete Message
