If you try to install LED's you'll get the fast you-have-a-bulb-out flash, and depending on the LED bulb, no running lights.
I removed the special light control relay and hazard flasher and replaced with this-
[image: Posted Image]'06 and newer flasher mod for LED
The flasher is the standard electronic '35'. Some label it 'FL','EL','EF',or 'FL'. The main thing is that it's the electronic version.
You will need to cut trace or pin for leg 7 on the IC. See here-
http://evnut.com/rav_flasher.htm
The blocking diodes could be any _001 or _004. I just happen to have a bunch of 7004's laying around.
All resistors 1/4 watt
The 2.8k resistors to ground are to get the flasher to see a load. LEDs present almost no load until they start conducting. If the flasher won't trigger with your bulbs, decrease the value until it does. If you get to 1k or less, you have another problem.
The voltage regulator is where you set the voltage level for the running lights. The regulator is good for 1.5 amps. I have mine set around 9VDC. At 9VDC both my bulbs draw less than a .25 amp, yours may be a little different depending on voltage and bulbs. The fuse is to protect the regulator from the use of standard bulbs.
I have it set so that if the hazard lights are on, the running lights are disabled to conserve battery. (I know, that was a little over the top)
I have another method that is actually simpler, but not sure if it would be legal. In that version, the front running lights would be full bright and would flash off-on with the turn signal. The problem would be that they would flash opposite the rears. Would that be illegal? Humm.....
Post up any questions.
