spring rate calulator
43 posts Started 31 Jan 2010 Last recovered post 23 Sep 2016 Wayback Machine snapshot 22 Aug 2019
Taken from another post
The ONLY way to know if the spring rate is correct is on the bike and checking both Free & Rider Sag, there is no other way!
I've said this in other threads, I think the problem is that most Pro's have a faulty spring rate calculator for the VFR model only and constantly come up with these bogus numbers. Almost always Too soft. :sleep:
So where do we find the correct calculator or formula for the do it yourself owner....????
With a single rate spring if we know the bike weight,rider weight, amount of pre load on the spring we should be able to calculate the needed spring weight. Any mathematicians out there??
Dan
Dan,
I have no idea who might have a good calculator for the VFR! I've yet to see any numbers supplied by any manufacture or suspension Pro that come close to the trial & error method Pete & I have been working on for years to achieve desired Sag numbers.
I forget what Pete has number and spring wise, but he's tried many springs to finally achieve the numbers he desired.
I weigh 190 lbs and have a 19 kg(1065 lb) spring on a Vtec, I get the following numbers measuring by myself:
Free sag- 12mm
Rider sag- 32mm
These are real close for what I want, but I want to check it again check it again w/help to be more accurate.
So IMO if you weight 190 plus you'll need at least a 19kg spring to get close, I'll be trying a 20 kg real soon and post my numbers.
BTW I started w/a 850 lb spring on my Ohlins and had No free sag w/35mm rider sag.
So besides trial and error there seem to be nothing for the do-it-yourself unless you use RaceTech or Sonic....Interesting
Dan
BaileyRock
Dan,
Free sag- 12mm
Rider sag- 32mm
Hmm RaceTech Cal says you need a 16.00 kg spring and your running a 19kg wish we could see the numbers that race tech uses..
Wistrick
Dan
That is true, but really you have a bunch of people here with setups that can get you into the ball park. And yes RaceTech's calculator is busted.
Wistrick
Dan
That's the point, who needs a calculator when you have members here who have done it right by Trial & Error and are providing accurate real world numbers and not some flawed calculator(for the VFR numbers only). :sleep:
As mentioned in other threads, I've seen spring rate numbers recommended to members here from just about every source out there World wide for a VFR (5th/6th gen owners) who weigh 190lbs that were from 800-1400 lbs. Who's right, there's only one correct rate and all the other calculators are flawed.
Actually you could probably be within the desired numbers with spring rates that are 50 lbs either side of ideal, maybe slightly more.
RaceTech has always been high on their fork spring calculator(IMO) and I'm not sure what happened to rear spring calculator as years ago they were Extremely High, now there Extremely Low for the VFR and both were wrong by real world numbers! :ph34r:
I guess my question is this. Both Race tech and Sonic have to use some type of formula and then take the #'s u enter and plug them in. Is there a way to find out the formula then maybe a person could look at it and see what was wrong.
here is what I have gathered so far.
Base on my weight of 250 pound both sonic and race tech come up with fork spring rates of 1.0
Differences in the calculators:
Sonic has you enter rider weight and the bike weight and Race tech just asks rider weight and Model type and uses its own # for bike weight.
Since both Calculators come up with the same spring rate we can assume that the bike weight Race Tech uses is at least pretty close....
Now I had my forks redone by GP Suspension and the spring rate they installed is .95. And my Free sag and Rider sag are in range. I measured the sags numbers 3 times and came up with a 2.78% error factor due to stitchion.
I guess I am just glad GP is doing my rear Penske Shock too.....
Dan
Get Tony Foale's book "Motorcycle Handling and Chassis Design" and his related software. You have to do a shit pot full of measuring of dog bones, swingarm lengths, rocker ratios, triangle hole dimensions, x & y coordinates of where all of these pieces pivot, blah, blah, blah.
I've got the software but haven't had the time to do all of the intricate measurements necessary.
One thing I did get quick and dirty out of his book so far: Jacking up the rear/lowering the front does not have the dramatic dynamic on weight transfer between the front and rear you would expect.
Wistrick
My nekkid weight is 255-260#. I use a 1300 # spring. I get 8 mm free sag, 30 mm rider + bike sag.
I'm not really talking about fork spring rate calculators as forks is forks tongue.gif
Where I see a consistent problem is with the VFR's rear spring rate calculators! I'm sure it's a simple problem in the dimensions someone has plugged into their calculators related to the rear rocker ration and all other parameters used, if you knew all the correct numbers you would think it would be pretty easy to build a accurate calculator. :sleep:
I'm sure if we were all on CBR's just about every calculator would be dead nut and they sell, race and build 100 fold more CBR's than VFR's, especially here in the states. :ph34r:
Wistrick
Base on my weight of 250 pound ....
Dan
Dan,
Unless GP suspension happens to be using the one and maybe only accurate VFR spring rate calculator and comes up with at least a 1200lb rear spring rate, It will be wrong IMO and you won't be able to achieve the numbers you yourself posted for Free & Rider Sag.
If they come up with something light like a 900lb spring and re-valve the Penske for it, the valving will be off by the time you get around to installing the correct and much heavier spring. :sleep:
BaileyRock
Wistrick
Dan
Dan,
You know the "Transformed Wow!" thread is one of the best threads going for info. Why don't we maybe add some setups to the front page or somewhere else that are working. We have the 3 of us so far with numbers that are 98% dialed in.
jasonsmith
Thanks,
I'll look thru the thread and find your set-up info or you guys can just post it up in the "Transformed Wow" thread and I'll add it to the original post and keep adding info from any member who achieves the desired Free & Rider Sag number for all members to see.
That way like you said members can see real world numbers and almost ideal spring rates for our VFR's by rider weight. :fing02:
BaileyRock
Wistrick
Dan
Dan,
If they come up with something light like a 900lb spring and re-valve the Penske for it, the valving will be off by the time you get around to installing the correct and much heavier spring. :fing02:
Well GP isn't just ordering a shock and spring from Penske and just shipping it to me, the shock will get shipped to them for dyno test and setup...But if its wrong they will make it right....We will see...
Wistrick
Dan
Dan:
You will need a 1250-1300# rear spring depending on your style of riding. I'd say be safe and go with 1300#. Up front you need 1.1 springs. You and I are both with just a few pounds of each other.
I ride aggressively in the mountains and I ride with a 1300#/1.1 set up. I run Diablo Corsa III's tires.
Pete
Pete
To all:
I will climb up on my soap box one more time.
You're spending $900-1300 for a Penske rear shock. You're spending $300-500 for a RaceTech/Sonic front end.
Spend $19.95 with Amazon.com and buy a copy of Andrew Trevitt's Sportbike Suspension Tuning and read it.
Pete
Pete McCrary
To all:
Pete
You da man Pete,
You are the one who sent me a copy of Trevitt's book and we've shared a shitzload of info, data and results for a long time trying to figure just what was important to proper bike set-up and spring rate calculations and just how vital Free Sag is to it. :fing02:
Keep Fighting to fight to help educate VFRD members one shock at a time! :goofy:
Pete McCrary
To all:
Pete
I have the book and have read it!!! I will call GP suspension and ask what size rear spring I am getting???
BTW I spent $480 on a GP suspension front end and $890 on the penske tongue.gif But you do make a good point.
Dan
Edited February 1, 2010 by Wistrick
BaileyRock
Dan,
Free sag- 12mm
Rider sag- 32mm
I also have an Ohlins 1085 lb (19.36 kg) spring on my lighter 5th gen, I'm 205 lbs w/out gear.
I understand the importance of selecting the correct spring but where are you setting preload when you decide a 19kg spring isn't right and you need to go to a 20kg? If you've got the preload set at 3/4 and all sag numbers are lined up, isn't that good enough? Would you bother changing the spring if you never carry luggage or passenger?
Here is a table that I've made using the calculations I've come up with:
Rider Weight Range vs. Shock Spring Rate (lb/in)
110-145lb = 1100lb/in
145-180lb = 1150lb/in
180-210lb = 1200lb/in
210-245lb = 1250lb/in
245-280lb = 1300lb/in
To be specific, a 250lb rider calculates to 1270lb/in. Since you can't buy a spring with that rate, you have to select the closest one available. I typically go up, in this case to 1300lb/in. There are other factors that play into it as well. Hopefully this gives you an idea!
I talked to GP Suspension this morning and they assure me they don't use any calculators. They order the shock from penske and they fit the spring to it. They use sag #'s to determine the spring rate...Guess what i am getting a 1250 or 1300 depending on dyno results...Sounds like someone has a clue...
Dan
Wistrick
Dan
LOOKS LIKE THEY'VE BEEN LOOKING AT OUR THREAD! :blink:
Dan,
That's great to hear that there's at least one shop that seems to be doing it right and seem to support what Pete & I and now Jason have discovered, congrats on finding them. Your bike should feel Great! :ph34r:
JamieDaugherty
Jamie,
Where was the problem in the flawed spring rate calculator you were using before? I remember it coming up with extremely low numbers for the VFR rear spring.
The Modified formula seems much closer to what we've been seeing on the higher end, but an 1100lb spring for a 110 lb rider seems extremely high IMO even for a 145lb rider.
If you continued down the scale with that formula to the stock spring rate of 15.3kg(850lb), the formula would suggest the stock VFR was built for a One Pound Rider! :ph34r:
Something seems amiss here!
What are your thoughts on this?
BaileyRock
Wistrick
Dan
Dan,
Dave from GP says they don't use those calculators on anything. The have there own data base they have created from real world numbers. He went on to say that if he didn't have those numbers for a certain model or brand say the new VFR1200 he wouldn't do work on the bike without it in his shop.
Will post some #'s for front and back once I get the shock in
dan
JamieDaugherty
JD if I take your 1270# and divide that by 250 I get 5.08. If I take that 5.08 and x by my 220# I get a 1117.6 spring which is very very close to being right. I think 1250# would be right for me for about 30mm rider sag. Also if I take the average Honda designed rider of 170# and x 5.08 I get 863# spring which is very close to what Honda seems to have calculated. 5.08 kinda seems like a magic number but it doesn't follow the rest of the numbers on your table.
Curious, what rider sag number is your target?
Wistrick
Pete McCrary
To all:
Pete
Dan
Dang, I'm even better at guessing what kind of money is being spent than the correct shock spring rates. :ph34r:
Pete
JamieDaugherty
Jamie:
Are you using a calculator, slide rule, or abacus? Those numbers look pretty good.
Pete
already have a WP 3-way with 180 (1028) spring I could use with some .95 fork springs...
if I have the correct spring fitted to the shock won't I have to get it valved to match the new spring?
218lbs. w/o gear
Edited October 27, 2010 by 04asphalt
04asphalt
218lbs. w/o gear
I'm not familiar with WP, but Ohlins says that their shock adjustments can cover the entire range of possible springs you can install.
IMO as long as your Not Maxed out on either side of adjustments and have the desired compliance than revalving isn't necessary.
No if you were racing the bike you would rather have the valving in the middle of it's range for said shock spring, but most street riders set and forget. :blush:
04asphalt
218lbs. w/o gear
been awhile, did I screw up getting 1.0 fork springs to balance the the rear 1028 (180) rear at my new 210lbs. birthday suit?
Edited February 12, 2012 by 04asphalt
Not really, how does the bike feel to you now???
.95's might have been enough, the 1.0 is Not that different, but I do think the the 1028 rear is soft for your weight and the 1.0 is too much for the 1028 rear.
I run .95's w/a 20kg(1122lb) rear and weight 190lbs.
Your set-up is very close, but maybe a little harsh on teh front and over working the rear slightly.
Baileyrock
just finished re-reading "transformed wow" and was thinking the same. thanks once again BR
Race Tech have updated their 'calculator' for the 6th Gen.
It now yields the following results for a 90 kg Street rider:
F: 0.987 kg/mm
R: 20.337 kg/mm
I ran the same scenario not so long ago (I forgot when exactly) and I got 17.837 kg/mm. :wacko:
PS: Yes, I know the last comment on this thread is going for 4 years old but it's still pinned so ...
While shopping for RT stuff for my VF500F2 I already pointed out that the weights used in their calculator are wrong or funky at least.
I spoke with one of their tech guys, asking what "semi-wet" was supposed to mean for their weight for the was way off.
RT say semi-wet is 180.5kilo
But the DRY weight is 185-189kg depending on year, kerb (so with ALL liquids) 202-206kg..
Dutchy
Actually ... the weight displayed by the RT calculator could be a fairly accurate sprung weight which is what spring rate calculations should be based on.
Ok so what is a semi-wet sprung weight then?
Semi-wet = all fluids but empty tank.
Sprung weight = basically the weight actually bearing on the springs i.e. not counting the wheels, brakes, fork sliders, some part of the swingarm...
Seen like this, the 218 odd kg used for the 6th Gen makes more sense.
Another suspension thread back from the dead, Good Stuff! :beer:
Here's Jamie's recommemdation with his fork spring ranges [from 'tranformed wow' thread]
"Here are the tables for a VFR800
Forks:
110-145lb 0.85kg/mm
145-175lb 0.90kg/mm
175-210lb 0.95kg/mm
210-245lb 1.00kg/mm
245-280lb 1.05kg/mm
Shock
110-145lb 1050lb/in
145-175lb 1100lb/in
175-210lb 1150lb/in
210-245lb 1200lb/in
245-280lb 1250lb/in
I would certainly suggest a set of 0.95kg/mm springs up front and a 1150lb/in (20.54kg/mm) spring out back. This would apploy to all street riders, the only time you would need to change is if you were an expert track rider on slicks. I hope this helps!"
Jamie, thanks for reposting this table. I was reading through this thread to see if anyone had quoted these spring recommendations from the 'transformed wow' thread. You provide a solid starting point for spring rate.
Jamie, one question to help refine the approach to your spring recommendations.
Question- are your rider weights for full rider with gear weight or do they reference dripping naked rider only weight?
6 hours ago, sfdownhill
You'll get a quicker response if you email Jamie directly. Jamie@daughertymotorsports.com
He is very friendly and is usually ready with answers...of course if he's not buried with work. I have had him do all three of my bikes BTW.
Thanks - I just received an email response from Jamie. He has great input as expected.
End of thread · 43 posts recovered Wayback Machine snapshot 22 Aug 2019
