i just taste the pipe.. if my tongue sizzles i know its hot. :fing02:
it gets hot enough to vaporize water instantly.. whats your concern here??? are you trying to see if the bike is firing on all 4? take a spray bottle of water.. run the bike.. squirt the pipes.. should go bbbbbZZZZZHHHHHHITTTTT! and if it doesnt .. you know something is not quite right at that cylinder..sometimes the idel jet is cloged one only.. sometimes the wired are bad or disconnected... :blink:
With an IR thermometor, from 1" away from the head to the first bend at least....I get 650+ plus within minutes. I think this is bad, but I want to verify with a known good motor. I seem to recall a previous bike running in the 350 range.
Started motorcycle, never touched throttle, all readings at the minute. I'm still fully assembled, so measurments were taken about 3" out from the head right before the bend downward. All temps in �F. My motorcycle is stock and seems to run normally.
