Unicam = Nothin Is New
12 posts Started 19 Mar 2010 Last recovered post 27 Mar 2010 Wayback Machine snapshot 7 Apr 2012
Honda's use of the unicam where one set of valves is operated directly from the cam lobe and the other set is operated by a follower is a cool idea. They used it for space savings. I though, "way to go, Honda, keep on comming up with new and cool stuff"
Then today I was looking at the valve train of a Junkers Jumo 211b V-12 motor from a German WWII bomber, and I noticed they used the same layout. While this is a rather nerdly discovery, I though it worth mentioning, espescially because it is thought of as innovative in 2010, but it was being used in 1936.
back to your regularly scheduled oil thread...........
They should have used synthetic in that motor, as it is filthy.
ONE LOUSY REPLY AND IT'S TURNED INTO A DAMN SYNTHETIC VS. DINO OIL THREAD ALREADY!!!! :beatdeadhorse:
:unsure: :goofy: :laugh:
It's not a real Junker -it uses a cam chain instead of gears. I don't think they should count it.
You need a new engine for your pick-up? :unsure:
Look closer, the cam does not operate directly on the valve. Both intake and exhaust valves are actuated by cam follower/lever. :unsure:
That's cool, is he rebuilding it? That HAS to be a new cam.
Oh and its a three valve head too..., some body call Ducati.
I did notice those cam lobes have a pretty steep ramp on them as well.
Mate that's not a ramp, it's a hammer! That top end must have taken some serious grunt to turn over.
End of thread · 12 posts recovered Wayback Machine snapshot 7 Apr 2012
