Here is a heads-up to all of you guys and gals to keep an eye on your subframe integrity!!!
In brief:
The subframe on my 6th gen broke in three places, which led to a broken muffler pipe. When I say 'broke' I mean sheared off, as in no longer connected to the other side... :unsure:
These pics show where the breaks happened.
[image: post-10716-127098737894_thumb.gif]
[image: post-10716-127098738871_thumb.gif]
A little background:
I ride about 25,000km/year, and about 15,000km will be with the luggage, in various states of load. Now when I say loaded I mean about 5-15kg in each pannier + top box, + a camping bag (tent, sleeping bag, mattress, etc) lashed to the seat. So for all of you mathematicians that would be 30-60 kg or 65-130 lbs. additional load on the subframe. Granted the top box weight is extended beyond the seat, but the rest is loading the subframe pretty much as if a passenger is sitting on the rear.
The event:
Of course the frame must have been broken earlier and my bad that I didn't inspect things more closely :fing02: , but I found all this out when my exhaust note changed from sultry stealth mode to straight pipe roar in 10 minutes. Since the muffler system is mounted between the subframe and the catalytic (which is referred to the main frame) the repeated flexing cause the pipe to shear in two (I know, shear is not the right technical, but I don't give a... :woohoo: )
The repair:
Unlike some (most?) of you guys, I don't have a workshop, or many tools, so I have to pay to have the bike repaired. I figured I would have to wait forever for the replacement subframe, (I didn't feel comfortable with the idea of welding fatigued metal), but lo and behold it was stocked in Vancouver and arrived overnight. I guess it wasn't the first subframe replaced :idea3: . A zillion dollars later (I'm too ashamed to write the number) she is back on the road.
I take slight comfort in that fact that this failure was the FIRST thing that ever broke in 4 years and 88,000km. Of course I maintain things properly, (oil, chain), change consumables (brake pads, chain, tires, coolant, brake fluid) and did one valve inspection (50,000km), but that's it.
So I'm back on the road after 3 days at the dealer, with fresh PR2s and nowhere to go..lol. Time to start planning the next 'Great Ride' smile.gif
PS. I hope all that extra weight on the 7th gen went into the subframe. I looked at the pannier attachment (particularly the rear end on fender) and I didn't get a warm fuzzy feeling, although the front side seems to sit on the passenger foot peg pretty good.
