Elka response to spring rate question
10 posts Started 20 May 2010 Last recovered post 21 May 2010 Wayback Machine snapshot 7 Jul 2013
This is the reply I received from Elka when I inquired as to why they would put a 850 lb spring on their VFR800 shock.
"The springs on the shocks we originally sent out were very light and had some concerns from VFR riders, however the stock spring rate on the VFR is an 850lb per inch, and the vast majority of motorcycle manufacturers use a spring rate for an average weight rider of 170lbs-200lbs. It was clear to us that the intention of the VFR at that point was as a touring/ sport touring bike, but the major complaints on the OEM shock when we gathered feedback during R&D was that the shocks stock lacked damping capabilities, and heard very little feedback concerning spring rates being too soft. Therefore, the spring rates that we decided to use were benchmarked off of the OEM spring rate for a 170lb � 200lb rider. Unfortunately for us, most people who purchased a shock were using the VFR for more spirited riding than the intended use of the VFR, therefore requiring sag numbers that mere more consistent with sport bikes.
If your riding is as you described � spirited�, then I am assuming that your riding style is probably more consistent with how most sport bikes suspensions are configured, meaning stiffer springs to achieve sag numbers anywhere between 28mm-32mm of sag, rather than the typical 45mm of sag you find on touring bikes.
If you prefer, measure how much sag you currently have with the spring that is on the shock. E-mail me the loaded and static sag numbers and I can help you determine if the spring rate is indeed too soft for your riding style.
A replacement spring will cost approximately $110.00"
When you order those shocks you have to specify your weight, luggage/passenger, riding style, etc so shouldn't they install the correct spring based on that information??
FWIW: May just be my own bad luck but sent my shock back to Elka for warranty repair. Several emails went unanswered along with a couple of phone calls but it took nearly three months to finally get it back.
If they're saying a different spring to replace the original 850 on a used shock is $110; that's fine. If they're saying a different spring other than the 850 on a new shock is an additional $110 to the purchase price then they are full of it. What is the case here VFR-SPORT?
Or..... are you feeling dissed (and rightly so) because they are calling the VFR a "touring bike" and want to bring this to our attention? :fing02:
Yes, it is a used shock I purchased from a member on here. Now, I presume he bought it through the first group buy of the Elka shock and he said it was setup for a 180 lb person. As I am 185 lbs, I didn't think I would need another spring. My question to them was why would they build a shock and put the same spring rate on it as it came OEM. I already let them know that no one I know would ever call the VFR a "touring" bike.
$110 is way too much money for a motorcycle shock spring. You shouldn't have to pay more than $80-90.
hrpworld.com
Elka is actually pretty good. What they told you is what I have already heard from them and I understand their philosophy. That is why their spring calculator tops out at 1100#. $110 is their flat rate spring cost. Don't forget, smarties at Honda aren't idiots either. They intentionally designed the bike with a lower spring rate partly to meet the sport/TOURING flavor and some because they think all riders are 165lbs. The 1000RR's aren't coming with 45mm sag.
Pete don't forget us CDN's have to fight with high shipping costs, exchange and tax at the border. You know I got my 1200 at Ground Control for $69 but even by the time it got to my door the Elka $110 was just a little more for the exact same Eibach spring.
i think all the shock maker sare brain dead about the vfr.
i called ohlins and ordered a spring.. i told them i weigh 220 and often have a 110 lb babe on the back.. they sent me a 799 sring.. how stupid is that?? :fing02:
That is absolutely ridiculous. Someone went hard on the pipe before filling your order.
...i told them i weigh 220 and often have a 110 lb babe on the back...
220 vs. 110! Let me guess who gets on top.
So much for NAFTA. :biggrin:
End of thread · 10 posts recovered Wayback Machine snapshot 7 Jul 2013
