In an attempt to avoid having to cut and weld the brake stay for my f2 swap, i am going to attempt to make an adapter ring to bolt onto the f2 wheel that will allow me to put the vfr rotor onto it. What i need to know is id of the rotor, and bolt pattern dimension. My bike isnt at my house and ive got no other rotors lyin about.
rear brake rotor: need some measurements
3 posts Started 18 Jun 2010 Last recovered post 14 Jul 2010 Wayback Machine snapshot 4 Jun 2011
Anyone? It looks like the vfr rotor is the same as the honda blackbird rear rotor
[image: View Post]flyguyeddy, on 19 June 2010 - 08:13 AM, said:
Anyone? It looks like the vfr rotor is the same as the honda blackbird rear rotorHere you go CBR F2 rear rotor dimensions: http://metalgear.com...p?partno=20.035
Bolt hole circle: 125mm, 4 bolt, 10.5mm hole diameter.
End of thread · 3 posts recovered Wayback Machine snapshot 4 Jun 2011
