[image: View Post]cornercarver, on 16 July 2010 - 08:36 AM, said:
[image: View Post]flyguyeddy, on 16 July 2010 - 07:34 AM, said:
[image: View Post]SEBSPEED, on 14 July 2010 - 05:23 AM, said:
[image: View Post]Franko!, on 13 July 2010 - 11:00 PM, said:
[image: View Post]flyguyeddy, on 23 June 2010 - 12:14 PM, said:
Bike is an 86 vfr 700 and id like to use a set of f4i forks ive got on this bike. Are they going to be long enough with a 17" wheel front and back with no raise to the rear suspension? Maybe it will make the bike sit level?
The 86 VFR has 835mm forks. The F4/F4i has 750 mm forks.
Your front end will be about 85mm lower. With any different front end, make sure the front tire does not touch the cylinder head at full bump or you will lock the front and crash.
A buddy put on a 929 front on his 86 VFR and did just that. He milled a custom 1" offset top triple to resolve this issue.
Franko, when you say offset, do you really mean offset? As in, he moved the forks forward in regard to the steering stem by 1"?
Or, do you mean that he added a 1" drop to the upper triple clamp? If this is the case, then my next question is if he was already using a drop-style triple from the 929/954, or if he had a flat clamp(like RC51 maybe?)?
Flyguy, you really ought to jack the rear end up to retain your geometry(rake/trail).
Why would i want to raise the rear end if im lowering the front soo much with the new forks? Wouldnt that cause extreme angles? This bike will be rode by my ex, so i dont exactly want it too twitchy. (We're still friends,if anyone is thinking foul play lol)
Depending on the front triple clamps and their geometry, you will most likely have to raise the rear and drop the front the get back to stock steering feel. I you dont, when ridden back to back with a standad VFR, the F4i forks will make the "upgraded" bike feel like a chopper.
but putting on the f4i triples will lower the front anyway, right? being as the forks are much shorter.
