[image: View Post]sjsartwork, on 05 July 2010 - 01:05 AM, said:
[image: View Post]timmythecop, on 05 July 2010 - 12:58 AM, said:
[image: View Post]flyguyeddy, on 04 July 2010 - 06:37 PM, said:
More often than not, the "white labcoats" get superceded by the bean counters when it comes to performance stuff. Plus, max horsepower isnt high on the priority list for white labcoats.
But then again, grip heaters, sidebags and all kinds of other things werent put there stock, but it doesnt seem to phase people putting thosr on, and the white labcoats never intended those to be there either. Not a personal jab, just food for thought ;-)
if you think there is a possibility of 8 extra hp by dropping the motor, exchanging cams and putting it all back together, be my guest. I f you think that bolting in a different cam will be "better" you are just wrong. Honda gets no points for an inefficient motor. I f there were 10 free horsepower lurking, Honda would have used them. You get all excited because you saw a graph on the internet. 5 more mm of lift means absolutely nothing if the carbs, ignition, and bore and stroke are set up for something else.
...like i said before my bike is a ca. model which needed to meet emissions requirments....personally i think theres room for improvement, you dont think so...but lets hope to hear from someone whos actually tried it or at least people with an open mind.
experimentation can lead to ?????who knows ; )
dropping the engine is hardly required for a cam swap. if our engines had a cam chain with no master, then i might be tempted to agree with that. getting to the camshafts on our bikes is very easy, if i were local i would come and help you.
you seem to have taken what i said as a personal jab against you, and that was not at all what i was trying to do. i was just making an illusttration that no motorcycle is optimal from the factory. if that were the case, then aftermarket exhausts would not be sold. saying that a cam swap with more lift and duration wont make more power without supporting mods i can totally agree with. but his bike is a ca model, and you can bet your lucky stars its way detuned from the factory to meet californias emmissions standards.
