New Exhaust with lots of Photos
28 posts Started 22 Jul 2010 Last recovered post 10 Jun 2011 Wayback Machine snapshot 14 Jun 2011
Finally got my exhaust in and installed. It's even better than I had hoped for.
Stock Set up we are all familiar with.. . . .
Loose fit up photos
Final assembly photos
This last photo is with the silencer spuds removed.
My only question is what are these two round things for?
My only thought is that they would go in the base of each can and act as silencers and restrictors in order to keep the stock fuel map happy.
I only have two minor complaints. one is for how visible they made some of the attachment springs and two is that there was a general lack of mounting instructions. Not to mention the incredibly small diagram they send with it.
But the sound with the silencers removed , , , , , , , :wub: , , , , There is just the nice DEEP rumble and when you are getting under way it sounds so nice. I really think these are better than Staintunes. No sharp or tinny noises at all. Just that growl that reminds you of a nicely tuned V8 rumbling by. I'll try and get a video posted later this week.
Looks good,
audio clip is needed!
[image: View Post]Ripper, on 21 July 2010 - 09:51 PM, said:
Looks good,
+10!!
Kewlness!
Thay look pretty nice, exposed springthings or not.
very nice. Can't wait to hear it
nice looking cans! :laughing6-hehe:
but you really ought to do something with that mudflap!
Like the endcaps!
They look great, where did ya get em from?
Congrats! :fing02:
Those are both functional cans, right? Not one real and one dummy can? :unsure: I want to upgrade to a CF exhaust system but want a systen where both cans are functional.
Regardless, they look great -especially on your silver VFR. Looks like the caps and other hardware matches the passenger footpegs nicely.
That is next on the list of mods. At least when I can get back to it. Remodeling a house is time consuming :dry:
I got them from the Italian Motostyles promo in the Bargain Finder Area "HERE" except I got in on it when the price was 20% off.
[image: View Post]TimC, on 22 July 2010 - 07:25 AM, said:
Congrats! :fing02:
Yup both cans are functional. I think over all It weighs about 6-7 lbs less than the stock set up. I weighed each part before I put it on but I need to add it all up to see what the difference is. :cool:
I called Leo Vince a couple of weeks ago and spoke to a rep, he said the end caps can be purchased seperately and simply installed for those of us with the old style. He wanted me to measure my cans so he could part out the exact cap and pricing would be apx $100 for both. I love the new look and I'm definatly gonna go this route.
[image: View Post]toddulu, on 23 July 2010 - 12:16 AM, said:
IMHO it does wonders for the looks if you just remove the plastic part, and paint the metal bracket behind it black. Doesn't cost anything either...
I was looking at that bracket and thinking the same thing. I might give it a try.
Those discs??...Minimoto brake discs..... :491:
Chombi
Ride Report -
At first I was concerned about fuel mapping since I don't have a PCIII or the like but all seems good. No sporadic fueling no abnormal popping on decel. The transition is smoothed out a little but not much. The front wheel seems to be able to loft a little easier with my 290# arse on it. I did put the Silencers back in this morning to see if they made any difference. They muted the sound quite a bit. making the system a little louder than stock and takes that bark out of the sound of the open pipes. So a good thing to have if you need to keep neighbors happy when returning home at the small hours of the night or early morning. The butt dyno didn't tell me if it made a difference in HP or not. I can tell there is a weight difference up top as setting it up right off the side stand is a touch easier.
All in all I like them except I'll leave the silencers out and throw them in the tail bag in case I need them for some reason.
Cheers,
CG
love those piepes, thinking of changing out my Laser Xtreme's for these. Do they come with black tips do you know?
As far as I know they don't. But you could probably give L.V. a call and see. If not then you could always have the tips powder coated or painted.
You can also, simply take a dremel to the plastic and follow the contour of the upper section, under the plate location. A little fine file work and tada, your stylen.
Nice looking cans by the way, like the CF and the oval.
Nice looking pipes on the bike. Does anyone know if these are EU compliant regarding noise/db levels? Are they fairly quiet with the spuds in?
I don't know about the EU compliant but I can tell you that they are quiet with the spuds in, just a little louder than stock and lighter. If i could get my camera to record the sound right I'd post it up but it's being stubborn.
You don't even have to do that. Simply remove the whole plastic cover all in one piece. Then just use the support bracket itselF for the plate.
any sound clip yet? I just emailed Giovanni to see what kind of pricing he is offering.
Does the tail really need to be removed for the install?
Yes it does.. it's 4 screws to remove, super easy!
When you install the exhaust, install it in pieces starting from the cat and work your way up aligning things as they go. I tried assembling it all and then mounting it.. what a pain in the ass. I took it all apart and started piece by piece and everything fit real nice. I ended up using one spacer between the exhaust mount and the oval bracket of the CF exhaust so everything lines up nicely.
I also have factory hard bags and everything clears quite nicely.
Ok thanks for the information.
I installed mine last night and all went ok. My box did not come with those 2 round things.
Anyway, the sound is awesome.
Pics coming soon.
The system looks great....As far as where the springs go, I'd rather have them where I can work with them, as opposed to looks(but I also like the look of the mechanics showing.).
Anyway... Waitting for the sound video.
Nice Job! But yeah, I'll join the chorus. It makes the gargantuan OEM mudflap standout even more. Here's mine with the SBK's and Competitionwerks fender eliminator. This is the day I mounted them. Later that day, silencers came out and have stayed out!
End of thread · 28 posts recovered Wayback Machine snapshot 14 Jun 2011
