5th Gen 2 Bros slip on
2 posts Started 22 Jul 2010 Last recovered post 22 Jul 2010 Wayback Machine snapshot 11 Jun 2012
Mine doesn't. It barely accepts the header pipe, and moving the midpipe to remove the rear tire is a serious PIA because it fits so tightly (it basically seizes). Anyway, I paid $80 to have the section of pipe that fits over the header pipe cut off, and another section of pipe with a larger diameter welded onto it. To say the craftsmenship is crap is an understatement, but at least it fits better now. I'm wondering if I'm the only one with a midpipe with this problem. I've noticed that the stock exhaust and midpipe (they're attached) fit loosly over the header pipe and are easy to move and remove.
Mine fits fine.  Where the midpipe meets the header, the 2bros pipe has 2 slots cut longitudinally up the pipe 180 degrees apart.  I just loosen the clamp and it pulls right off.  Maybe there is a material you could put on the header to prevent this - copper anti-seize?  Someone else may have a better suggestion than that - something exhaust system specific.
End of thread · 2 posts recovered Wayback Machine snapshot 11 Jun 2012
