Is the O2 eliminator kit required for a Power Commander install on a 2008? Thank you.
6TH Gen PCIII Install
6 posts Started 24 Jul 2010 Last recovered post 24 Jul 2010 Wayback Machine snapshot 15 Jun 2011
[image: View Post]spaceman, on 24 July 2010 - 09:12 AM, said:
Is the O2 eliminator kit required for a Power Commander install on a 2008? Thank you.They're required for pretty much any add-on fuel controller, and definitely for the PC3.
Thanks. I wasn't clear on that because the PCV includes them, where as the PCIII does not. Plus, I didn't have to deal with them when I installed a PCIII on my Ninja 650.
I don't know if your Ninja had O2's or not so I could say what that's about.
What's going to happen if you don't is the factory ECU is going to fight the enrichment the PC3 is trying to add. As for the terminators, just buy 330 ohm resistors from somewhere like Radio Shack, install them into the plugs, and tape it all up nice and clean. A whole lot cheaper and they're the same thing electrically.
Is the O2 eliminator kit required for a Power Commander install on a 2008? Thank you.Why PCIII? PCV would be a much better, given it's an '08, and the cost is about the same.
Yeah, guess your right! Just had PC III on the mind. Thanks guys.
End of thread · 6 posts recovered Wayback Machine snapshot 15 Jun 2011
