Here is the pipe I broke down and bought for my 5th gen. $226 to my door. Very nice looking, great build quality to this 350mm long pipe But, I got shorted one clamp (doesn't everyone?) Please fix this Delkevic already this is a 3 year old problem I keep reading about....annoying. Anyways they are sending another clamp but I would like to ride it tomorrow when the copper sealant dries. +1 on Delkevic customer service by the way.
1) Is it safe to ride without the clamp from silencer to mid pipe?
2) How do you remove the baffle? I took the screw out and tugged on the baffle with everything, what's the trick?
Go to Lowes and get a hose clamp, till the ss clamp gets there..... One for a 5" to be safe.... The pic doesn't show but I think you have a strap around the muffler, if so you should be ok.... but I would rather have the clamp on as well.
OOP's, I see the clamp, i'd do the Lowes thing 1st...... It's possible to work loose......
[image: View Post]Toppers, on 27 July 2010 - 12:09 AM, said:
Cool thanks I'll do that. Do you need to seal that joint too?
If it fits tight I wouldn't bother, you'll find reasons to be removing that part once and awhile.... I've never had a problem with it leaking sound.... Not only does that look cool.... It is cool, at least it won't get hot enough to burn you....
I rode it to the store to get a hose clamp for the pipe. Damn, does it sound sweet. I can already tell I won't need to use earplugs on long rides, or put the baffle in after hours....it is just right. Well until I can get a better camera, here is a clip from the Iphone cam.
Looks sweet.....
End of thread · 6 posts recoveredWayback Machine snapshot 16 Jun 2012
