Ok I have the bars on and everything fits great. The instructions say to torque the bars pinch bolt to 12 ft/lbs. What do you torque the resevoir bolts to? And my torque wrench is in inches? Whats the conversion? Is it as obvious as 12in to 1ft?
Helibar install ?
5 posts Started 30 Jul 2010 Last recovered post 5 Aug 2010 Wayback Machine snapshot 15 Jun 2011
[image: View Post]taj8250, on 29 July 2010 - 09:16 PM, said:
Ok I have the bars on and everything fits great. The instructions say to torque the bars pinch bolt to 12 ft/lbs. What do you torque the resevoir bolts to? And my torque wrench is in inches? Whats the conversion? Is it as obvious as 12in to 1ft?you dont have the right torque wrench, you need one in foot lb
http://www.onlinecon....com/torque.htm ****** 12 pound foot = 144 pound inch
8mm = 9 ft lb ********** 9 pound foot = 108 pound inch
12 foot pounds is a good tight with the socket wrench, not cranking on it, but tight. I don`t use a torque wrench for anything under 20 foot pounds.
[image: View Post]VF1000RS, on 29 July 2010 - 10:43 PM, said:
12 foot pounds is a good tight with the socket wrench, not cranking on it, but tight. I don`t use a torque wrench for anything under 20 foot pounds.Not being a smart ass here, just curious as to why? Is there a chance of over-torquing, even with a torque wrench?
End of thread · 5 posts recovered Wayback Machine snapshot 15 Jun 2011
