Voltage Meter fitted
14 posts Started 29 Aug 2010 Last recovered post 31 Aug 2010 Wayback Machine snapshot 2 Oct 2010
Mini project over the weekend completed.
Masked the area where the meter was to be fitted.
http://www.vfrdiscussion.com/forum/uploads/1283082773/gallery_16926_5562_535957.jpg
Cut out the masked area using a very sharp knife
http://www.vfrdiscussion.com/forum/uploads/1283082773/gallery_16926_5562_140382.jpg
Snap the Meter in place.
http://www.vfrdiscussion.com/forum/uploads/1283082773/gallery_16926_5562_239384.jpg
Tapped into the Signal +ve power. Total time to fit 1hr.
Nice install! What meter did you use? Hard wired directly to battery? Wanting to add one to my Y2K model soon.
If you hard-wired it to the battery, how would the meter ever turn off? :wink:
picked these from ebay
http://cgi.ebay.com/...3AMOTORS%3A1123
I tapped into the signal +ve which goes to the relay. Didn't want to connect to anything that was linked to fuel or ignition. This is a good switched power source. The Shift light is also connected here.
Good luck !
Kewl! :fing02:
Is it water resistant/proof?
[image: View Post]enzed_viffer, on 30 August 2010 - 04:40 AM, said:
Kewl! :fing02:
I'm gonna say no, because the EBAY auction didn't mention it.
If waterproof was a feature, the seller would definetly list that.
I have one similar to that one and I mounted it in about the same place on my 5th gen. I wish now that I mounted it higher on that cowl because my handlebars obstruct the view a little. Higher would have been a simple glance down to the meter. Yours may be different.
You can put some clear plastic over the meter to make it somewhat waterproof. I never had trouble with mine after I did.
its definitely not waterproof but i think i took care of it. The under circuit i coated with silion and put a little silicon glue between the blue lens and the black frame. I thinks its good.
It's my experience that tapping into a harness wire will display a reading a few tenths of a volt lower than one taken directly at the battery. It's a PITA but running a switched relay from the + battery terminal will give you the most accurate reading if that is important to you. It wasn't for me. I just compared the two and mentally added it back in. Kinda' like you do with the factory speedometer error. :biggrin:
So is this really a $3.99 + $6.99 shipping mod? If so I'm in...
Nice job but at only 12.4 Volts you may need a new battery.
It never rains in Mumbai anyway! Right Anik?:laughing6-hehe:
Lee - RIGHT !!! it has been pouring for last couple of days. At this point we are towards the 80% of the monsoon season and should get over in a month or too. Jul/Aug are the peak months and gradually reduces in Sep/Oct. Thats for the Weather forecast :)
Fotomoto - you are right. I have ordered a Fusebox which i will use for all these accessories. Will have the relay fitted at that time.
danmurphymn - the product is from China so the cost of shipping to India and the US will be the same. I am sure there are similar products out there being shipped from the US.
mechdziner714 - I usually shut the bike down during the monsoon season. Taking the bike out in the rain is like 30 min of pleasure and 3 hrs of agony to clean :D. The battery has gone down a bit since its not being used. Will give it a full charge in couple of days.
thanks for the feedback.
End of thread · 14 posts recovered Wayback Machine snapshot 2 Oct 2010
