5th Gen Rubber Nubbin
5 posts Started 8 Sep 2010 Last recovered post 8 Sep 2010 Wayback Machine snapshot 10 Jan 2011
Why didn't anybody warn me the little rubber bastard behind the forward rear cowl bolt goes shooting into the subframe rail if you push too hard?
It's there to fill the hole in the frame. The hole is there so that you can put a long screwdriver in and adjust the idle.
Ohhhhh, thanks. I guess I hadn't read that part of the manual yet. I'm leaving for a 3500 mile trip on Friday. The zip tie will have to do the trick for a couple weeks.
[/quote]
[/quote]
I belive Crabenho is talking about the uppermost mounting point for the rear cowl / tail section fairing - the rubber surrounded nut/ threads that is on the subframe; not the idle adjust hole on the right side of the main frame.
Lol, Crabenho - I've lost both of those rubber nubbins inside the subframe too. Just last night I ordered some new ones because I was ordering other hardware. Previously I was using some small red zip ties that went through the mounting tab on the rear cowl and throughthe nubin-less hole on the subframe.
Because misery loves company. I just replaced my 3rd one saturday. BTW, it is better to lose them than to have them sieze on the bolt and spin when you try to unscrew it.
note: my rear cowl is STILL held on with a zip tie since my lower subframe bolt broke off last week.
End of thread · 5 posts recovered Wayback Machine snapshot 10 Jan 2011
