Thanks....
Thanks....
[image: View Post]VF1000RS, on 22 September 2010 - 10:16 PM, said:
1986 was the first year with a stock oil cooler.[image: View Post]VF1000RS, on 25 September 2010 - 02:03 PM, said:
The double throw pump has one rotor for feeding the engine and one rotor for feeding the cooler. Designed by Honda for oil cooler use. You need to feed the cooler without stealing oil pressure from the motor.[image: View Post]Chev, on 27 September 2010 - 06:28 AM, said:
Why not just run the cooler in series?[image: View Post]SEBSPEED, on 27 September 2010 - 06:36 AM, said:
Why not just run the cooler in series?[image: View Post]Chev, on 27 September 2010 - 08:30 AM, said:
Why not just run the cooler in series?[image: View Post]SEBSPEED, on 27 September 2010 - 09:21 AM, said:
Why not just run the cooler in series?[image: View Post]sixdog, on 27 September 2010 - 10:54 PM, said:
]This is what I have on my Vf1000F...been on for 20 years[image: View Post]sixdog, on 27 September 2010 - 11:24 PM, said:
No...secondary radiator is behind the headlight.[image: View Post]buellosaurusrex, on 28 September 2010 - 10:43 PM, said:
No...secondary radiator is behind the headlight.[image: View Post]JamieDaugherty, on 30 September 2010 - 08:45 AM, said:
The cooler that sixdog shows is really the ticket. With the cooler sitting low you won't have any "drain back" issues causing you to get weird oil levels. In fact, there really isn't a lot of volume in the lines and cooler anyway.[image: View Post]buellosaurusrex, on 30 September 2010 - 12:00 PM, said:
