sargent seat problem
9 posts Started 25 Sep 2010 Last recovered post 27 Sep 2010 Wayback Machine snapshot 16 Jun 2011
My sargent seat seems to fit to tight and can be very hard to get off. Anyone have this problem, or know of a way to fix? It is a 2007 abs.
This is what I did to mod mine.......
Same for me, it does help to hold the key turned while trying to lift the back off. My seat only has a couple hundred miles on it, but it is getting easier to remove. It's still hard to get the rear to click in though, I have to push pretty hard on the center of the rear pillion.
I had the same problem with mine then I made the modifications that Monk suggested about a year ago. Problem solved.
The two outer areas were nobs and I wore them down (Psyc-101)...... The lock lope has plastic inside that was not allowing the lock hock to ingage so I removed some of that as well.............. Just do a little at a time till you have a fit that will allow you just push lightly......... Mind will drop on with out pushing now and feels tight when locked on.
Thanks this is exactly what I was looking for. I felt like a jackass the other day at the store, I had to ask this little old lady to hold the key turned while i pulled the seat off so I could get my helmet.
I have the same problem described with my Corbin. Taking it off isn't really a prob, but getting it to lock on properly is. I'll take a look at the seat pan and see if Monk's mods apply. Thanks! :fing02:
If it makes you feel any better, I had the same problem with my two-piece Sargent seat. Had to do some trimming to get it to lock and unlock correctly.
End of thread · 9 posts recovered Wayback Machine snapshot 16 Jun 2011
