[image: View Post]VFRSuperfreak, on 30 September 2010 - 04:40 PM, said:
[image: View Post]mikeodial, on 30 September 2010 - 04:02 PM, said:
[image: View Post]SEBSPEED, on 30 September 2010 - 10:36 AM, said:
Are you talking about clutchless upshifting? Or are you still pulling the clutch in part way?
I was not specifially talking about clutchless shifts, (although you can use preload on that also). Here I was referring to lightly preloading (some light pressure) on the shifter prior to the act of shifting and then using the clutch to upshift/downshift. (Hence the term pre-load which gets the shifter preloaded for the actual shift). You have to be careful not to exert too much pressure or you may find you way into false neutrals on some bikes (not the VFR I am sure).
Hope that helps.
So the technique is:
- Preload the gear you are going to use
- Throttle off clutch in
- Change gear
- Throttle on/clutch out
I'm not the sharpest but I tried to get my head around all that and came up empty.
Normally I just upshift with a partial decrease on throttle. That's all. I imagine that my brain already delegated part of this process to my tendons at both ends. No idea. I just go, down-throttle-shift, all day any road.
There are people that don't know what is going on with the shifting process...IE; can't get it in 1st while stopped(the fix is to engage the clutch just enough to make parts move), because they pull the clutch in all the way, so now some parts aren't moving and it won't engage...... Then we have people that are using too much clutch to run though the gears, because when they pull the clutch in to much, which allows the a gap in time for the rpm's and drivetrain to lose the momentum, and lose sync.......
This preloading is just a way to explain what needs to be done to make it run smoothly..... For the people that shift smoothly without thinking about it .... it may seem like "What's the fuss"......... But for people that are not getting it done this is a step by step how to..........
Like there are people that don't know that they steering their bike with their hands(think they're leaning).... so we tell them to steer the opposite way we want the bike to go.............
I think it's good when some training techniques can be explained in writing..... When I got my 1st bike in '65 I didn't understand how the bike gears worked at all and would start by pushing down once and go.... Because I thought they ment when you push down your in 1st.... needless to say I burnt the clutch out in a couple of days........They were nice enough to replace it at no charge even though I was totaly at fault..... But they did take the time to make sure I understood how it worked this time..... It sure turned me into a non gear-jammer from that point on.... as I became an "OTR" semi driver that got complements for not waking up the sleeper......
