I did a stupid thing today, when trying to remove the battery terminal to install a battery harness for heated gear. At first I tried to remove the negative terminal with the screwdriver but it was on too tight. So I got out a 10MM wrench when the wrench made contact with both the positive and negative post. It started to spark and I quickly removed the wrench, the wrench had few burn marks and was extremely HOT.
After the initial shock, I installed the battery using a socket wrench and hoped I didn�t do any damage. The bike started and shifted into D,S and manual mode, didn�t have time to take it out for a ride.
Could I have damaged my bike in anyway?
