Why is my chain still good at almost 18K miles?
13 posts Started 5 Oct 2010 Last recovered post 6 Oct 2010 Wayback Machine snapshot 18 Oct 2010
Still have the factory chain on my '95 (as far as I know...really doesn't appear to ever have been changed) and the bike has 17.8K on it now. I bought the bike with 12K on it.
I lube it with Maxima chain wax every 500 miles religiously by spraying it on a hot chain and then scrubbing the excess and grit off with a clean rag. I ride twisties a lot and accelerate hard a lot. I don't do wheelies. I use the engine's braking a fair amount.
According to the little graphic on the chain gaurd, it's not even 1/3rd of the way worn out. Many of the rollers are starting to look somewhat dented but none are missing and no O-rings are missing. I can't pull any chain off the rear sprocket. I have only had to adjust it twice since I've owned the bike. It isn't terribly noisy -- I can't hear it over the stock muffler.
Isn't it unusual for a chain to last this long or am I missing something really obvious indicating that it should be replaced?
nothing wrong with that....
i have gone from 20-50,000 miles on a chain as a bike courier. But admittedly mostly using a DID X ring chain...
Simply used a 'scott oiler', or when that packed up, just any old oil, thrown on with a small long brush before i go ride....
A standard chain properly maintained might reach 25,000 mile before it wants replacing from experience.
Your bike has hardly broken in! There's stacks of life in it yet!:fing02:
When chains go, they tend to want adjusting a lot more often than usual. You should be able to pick up the signs.
i have gone from 30-50,000 miles on a chain as a bike courier. But admittedly mostly using a DID X ring chain...
A standard chain properly maintained might reach 30,000 mile before it wants replacing from experience.
Maybe you don't ride it hard enough????
Try to launch a few wheelies and some hard acceleration sprints to get that thing stretched out!
Beck
95 VFR
They just don't make chains like they use to! :biggrin:
its still good because you lube it when it is hot and you wipe it with a rag, not a brush. I got 27,000 outta my last one with very, very little care. (O rings hate wire brushes)
Congrats on the chain life. Make sure that the sprockets are also in good shape as they are a part of the system.
What's your typical MPG? How many miles do you get out of a rear tire? Are you 100% sure the PO didn't change it?
Proper maintenance (I have a Scotoiler) and keeping an eye on tension made my chain last -rough guess here) some 30k miles.
don't do wheelies (do burnouts count? :biggrin: ) but that chain does get used for sure
so no nothing wrong with it...
I guess that's my problem, I love wheelies! :blush:
Avg. 15-20k from a high end D.I.D. chain.
MPG is anywhere from 40-46 depending on what kind of riding I've been doing -- lately closer to the 40 mark. I put a new set of PR2s on the bike when I got it and the rear tire still has about 50 percent of its life left easily...so like 10K miles for a rear tire but that IS a PR2 which last forever anyway. I'm 99% sure the chain was never replaced. The PO was only the second owner and. he bought the bike with about 3K miles on it and rode it to 12K when I bought it. The chain had some rust on the side plates which I cleaned off when I got it.
:+1: About 18k is all I get on the VFR too. Of course with a Scottoilder on my VTR, the chain lasted 40k, and I HAD to do a wheelie on that every time I rode it. :biggrin:
I want to learn how to do wheelies :(
talk to SebSpeed.. I'm pretty sure he thinks he's saving money on front tires, by trying to keep them off the ground as much as possible. :laughing6-hehe:
End of thread · 13 posts recovered Wayback Machine snapshot 18 Oct 2010
