1994 Steering Head Adjustment
6 posts Started 7 Oct 2010 Last recovered post 8 Oct 2010 Wayback Machine snapshot 18 Oct 2010
Just back from getting some new tires installed on my '94. Service guy said that my steering head bearings need to be adjusted. I replaced the set in my old 1986 VF500 when they were notched, but these are just a little sloppy on heavy breaking. I'd love to just torque it down appropriately without doing the replacement, that was a major PITA. Anyone know what size socket I need to fabricate the steering head tool?
Or even better, have a tool available for loan? :beer:
I just took/bought a piece of pipe (1 13/16" OD) and cut one end down leaving just two pins to slide into the castle nut, more than enough to torque to required number. I welded a large fender washer to the top and then welded a large nut to that so i could use a simple socket on it.
:fing02:
[image: Attached Image: tools.jpg]
Send a PM to Veefer800Canuck, he knows the size. I bought the Honda tool.
They're really not that bad to do - just a little time consuming.
Be careful....VFR steering heads have a track record of being over-tightened and made worse.
Or you can just use a hammer and a punch... that's what I did, worked great!
I ended up using a spanner for a shock.. worked like a champ... BUT I have tapered bearings installed, which apparently don't use near the torque numbers that the stock setup does..
End of thread · 6 posts recovered Wayback Machine snapshot 18 Oct 2010
