Fuel injection conversation
2 posts Started 7 Nov 2010 Last recovered post 7 Nov 2010 Wayback Machine snapshot 17 Jun 2011
Well, I would like to discuss with You all this topic, as I am in the middle of a bike project (old RC36) :goofy:
I assume we all know what it is, but just in any case, here You can find some basic info: click
So the main question is how can I do it ? I've seen many bike projects here, but none of these, described such a modification.
I took the idea from a guy with Vmax who did this. He used throttle bodies from GSX-R K5-1000 and custom injectors.
What about VFR ?
I've had a 'quick' look into EFI before.
Microsquirt or Megasquirt have both been used to convert carb vehicles to EFI
Looks as if you can use many different throttle bodies, injectors and sensors. Adding a cam pulse sensor to the existing motor could be 'fun' but believe there are ways round it.
I would suggest finding some like the guy with the Vmax to guide you though what needs to be done - be prepared for a lot of reading and then setup once you have everything installed.
Ask yourself do you really 'need' EFI as a good standard carb setup works.
If you bite the bullet and go for it (which I think you should) please share you experience with VFRD! :beer:
Red.
End of thread · 2 posts recovered Wayback Machine snapshot 17 Jun 2011
