Why Inverted Forks?
Example... The seat is sprung.... the wheel is unsprung.... the top of the fork is sprung, but the bottom part is unsprung.
No dumb questions....... just some dumb answers.
[image: View Post]gll429, on 07 December 2010 - 12:52 AM, said:
but the main reason.. the look bitchin! :cool::goofy:
Only because they're better ...... Of course I think springers(the old type) are bitchin' and they don't come close to being better..
AHA!!! THE TRUTH COMES OUT!!! :laughing6-hehe:
C
That's why I got myself one of these:
Still a bit more involved than regular forks, but sure makes life easier!
Fully adjustable (preload, compression damping, rebound damping) and BRAKES!
The rest, IMHO is nice, but hardly worth spending $$$$$$ for if that's your only reason.
legs is the degree of fork tube over lap... the old legs were limited
to the amount of over lap by bottom of the triple trees... whereas the
new inverted fork tubes can overlap right pass the lower triple tree
clamp... this double overlap of the fork tubes pass right through the
critical lower triple clamp junction and offers a instant more ridgid
feel to the steering and suspension action... A rider going from the
old standard legs to the new inverted forks is like going from an
analog front end to a digital front end... the difference can be like
night day because standard telescopic forks are poorly supported due
to limited overlap whereas inverted forks are amply supported due to
overlapping fork tubes at the critical triple clamp junction...
Overlap study of a 41mm inverted fork and a 45mm standard fork... the
standard weights 8lb 4oz and has 160mm of overlap whereas the inverted
fork weights 7lb 13oz and has 360mm of overlap... someday the standard
will be inverted forks just as the standard is now disc brakes over
drum...
I found out one day when I sighted down the fork leg of my 95 while pulling at the bars to turn the front wheel. There is acutally a sort of delayed action between the bars/triple calmp and the wheel itself, indicating quite a bit of flex.. After adding on a fork brace the flex was substantially reduced and the front end suspension compliance and handling performance was greatly improved on my bike, but I think I still detect a very slight hint of flex left when I do the same test after the brace was added on. I guess.the only way to remove avoid this last bit of flex is to go with upsideown forks. That's why the biggest item on my wishlist for many years with the VFR has been to add in upsidown forks.........like most of the other manufacturers had already done on their bikes for so long already......
Beck
95 VFR
[image: View Post]Stealth, on 07 December 2010 - 05:39 PM, said:
I can't believe no one mentioned the two TOP reasons!Fully adjustable (preload, compression damping, rebound damping) and BRAKES!
Just for the record....Fully adjustable (preload, compression damping, rebound damping) is also available on regular forks, which might be why that wasn't brought in to it.... Just for people that might not know that.....
drum...
[/quote]
So - as long as we're on stupid questions - why doesn't Honda just make 'em inverted to start with? They seem fine for the RC51 & others . . . They probably just want to make 'em a limited production thing to seem exclusive so they can charge more $ and get us to run around buying parts to do conversions. :dry:
[/quote]
As I noted, other manufacturers hav gone to upsidown forks a long time ago for most of their higher end bikes. I suspect Honda's bean counters have been responsible for the long wait for upsidown forks on the VFR. They finally have it on the 7th gen. but that was just too long a wait for all of us. It should have included way back on the 5th gen already. I guess they wanted to avoid the embarrasment of trying to put in regular forks again on to what Honda considers as their techno flagship with the 7th gen. The bean counters might have finally lost against the engineers at Honda, otherwise we might have still seen regular RSU forks on the 7th, the way things were going. :dry:
Beck
95 VFR
Don't know about you. My stock VFR forks only had preload. :dry: Now my Ohlin forks, shock and Brembo brakes. That's another story. :wub:
I think Monk's point was that you do not have to go with upsidown forks to get rebound and damping adjustment features. many RSU forks have those features way before upsidown forks were ever sold to the public.. The VFR only had preload because they wanted to keep costs down.
Beck
95 VFR
Beck
95 VFR
Sorry, my sense of humor failed me. :blush: Should have used this instead. :goofy:
