transmission ratios
1 posts Started 30 Jan 2011 Last recovered post 30 Jan 2011 Wayback Machine snapshot 16 Jun 2011
Hey guys, has anyone ever tried to change the transmission ratios in the gearbox on a 5th gen? 1st and 2nd are the same on a sixth gen but 3rd through sixth are taller. I would assume because they went with a 16/43 final drive as opposed to a 17/43 on the 5th. Reason for asking is, if you went with a 45 tooth rear and changed 3rd through 6th you could get the low end pull in 1st and second and lower rpm for highway cruising in higher gears.
End of thread · 1 posts recovered Wayback Machine snapshot 16 Jun 2011
