Seized caliper slide pins
9 posts Started 3 Feb 2011 Last recovered post 4 Feb 2011 Wayback Machine snapshot 4 Jun 2011
hi
How do I go about freeing a seized slide pin on an 87 VFR 700 F2
Part 13 Part Fiche
Roger
[image: View Post]artee, on 03 February 2011 - 03:44 PM, said:
hi
Part 13 Part Fiche
Roger
gently tap it out with hammer and punch.. file down and marks made by the punch... clean it off with scotch bright .. grease the hell out of it as well as all the rubber boots.. reinstall. :fing02:
Yeah, pretty much you just need to use whatever means necessary to get it out. If it's damaged too badly in the process you'll want/need to replace it, otherwise you can clean it up and reuse it.
Spray it with PB Blaster and let it set for a bit.
PB Blaster is great stuff. Just make sure to keep it away from any brake pads you plan to use again.
You need to put the straw of the spray can inside of the boot to get some penetrant in there. Let it get to the pins and work it loose.
Try to use a punch that is as close to the same size of the pin as possible(but smaller)
Looked like the only thing left to add... 2-cents. :biggrin:
Apply heat to aluminum caliper to expand the hole... a light tap is what you use... any time you use extreme pressure on motorcycles parts things start to deform...
Is that the stuff we use for sore muscles :laughing6-hehe:
End of thread · 9 posts recovered Wayback Machine snapshot 4 Jun 2011
