I bought my 5th gen with GenMar risers on it. I want to check out the stock bar position. Looks like if I remove the risers, I'll need to replace the "51405-MB4-003 ring/stoppers". (I don't have them.) Are these just regular snap rings? Best source to get them?
Removing GenMar risers
5 posts Started 6 Mar 2011 Last recovered post 6 Mar 2011 Wayback Machine snapshot 16 Jun 2011
[image: View Post]skymon, on 06 March 2011 - 11:02 AM, said:
I bought my 5th gen with GenMar risers on it. I want to check out the stock bar position. Looks like if I remove the risers, I'll need to replace the "51405-MB4-003 ring/stoppers". (I don't have them.) Are these just regular snap rings? Best source to get them?You can go to links at the top of the page. Here is one I pulled from there.
http://www.vfrdiscus...s&gotolink=1080
They are not exactly snap rings; they are simple rings of wire that fit into the groove in the fork tube and the corresponding groove in the clip-on. (The seem rather expensive from Honda!) I'm sure many, many of them have been lost over the years without anyone bothering to replace them. I've bought several sets of eBay 41mm forks, so I'm sure I've got some extra somewhere, but I'm not sure where that is at the moment...
You Don't need them as they serve no real purpose unless you forget to tighten the pinch bolt, but you couldn't ride the bike if you did anyway! :blush:
I've not run them on any bike and have more than 100k miles on VFR's alone. :beer:
Got it. Tighten the pinch bolt. Skip the ring thing. Thanks.
End of thread · 5 posts recovered Wayback Machine snapshot 16 Jun 2011
