ok,
so I've taken my forks off and in lieu of taking them appart I've found a way to mask off the internals (removed the seals and substituted them with a plastic thing that comes as a protector on a roll of teflon tape, as a barrier for anything foreighn to fall into the forks), in order to stip the bubbling/peeling gray paint from the leggs.
I've done a good job at removing the paint and sanding down some of the corrosion/oxydation from the exposed metal, and have matticulously masked off all lthe mating surfaces/ holes on the fork leggs.
I'm ready for a few coats of primer.
I've picked up a nice gold flake duplicolour engine paint. I figure that will be a fairly tough paint to stand up to rocks and such...
NOW FOR THE STUPID QUESTIOS:
the can states that for best results its recomended to heat cure the painted surface at 200 farenheit for 1 hour.
that being the case, I'm wondering what that temp would do to the internals of the fully assembled forks? would the oil break down/damage? other parts get damaged?
It doesn't sound like a good idea to me - to bake your forks in an oven for an hour at 180 or so, and I probably wont do it, but just thought if anyone had any thoughts otherwise...
now I guess my other question is, how big of a job is it to take the forks appart and put them back together? the cost is equivalent to new oil, and a set of new fork seals. I was going to get ne seals anyhow, but wasn't planning on changing the oil in them...
If I do take them appart, what do I have to look out for? immaculately clean working area, and wrapping up all the internals into virgin garbage bags to make sure that no particles attach themselves to any part of the internals, is what I figure would be a good way to go about it...
what type of oil will give me a better ride from stock?
ok,
hope you're not laughing too hard at my dumb questions....
and that someone has some answers...
thanks in advance!
ok,
thanks in advance!
