Carb Sync Problems
7 posts Started 14 Apr 2011 Last recovered post 15 Apr 2011 Wayback Machine snapshot 4 Jun 2011
So recently i took apart my carbs and cleaned everything and i was attempting to bench sync until i noticed that one of my carb sync screw holes is slightly larger than the other ones so my screw isnt grabbing to tighten. Any suggestions to fix?
Screw holes? I don't think I understand.
Do you mean the lever-thing that is threaded for the screw to turn, and is linked to the butterfly?
I can't imagine that the metal in the lever would strip out, the screw is much softer metal than the threaded lever...
Maybe some pics?
I have a rack of parts carbs but I'd love to see some pics...
Yeah, pics would be helpful to see exactly what you are talking about.
Silver solder a nut on the back side if possible !!!!!
You could use a screw the next size up and tap the hole for it.
are you reffering to the screw that goes into the side of the Intake port?
....and theres 1 for each cylinder?
If needed they are available from Honda.
I think he is talking about the throttle stop screws . The FSM calls them "synchronization adjusting screws" , but contrarily calls the special tool to adjust them a "pilot screw wrench".
End of thread · 7 posts recovered Wayback Machine snapshot 4 Jun 2011
