rear shock compression damping
2 posts Started 1 May 2011 Last recovered post 1 May 2011 Wayback Machine snapshot 11 May 2011
After putting an initial 800 miles on the bike, 2-up, over 2 weekends I noticed that the rear was a little wallowly. Thought I'd look to dial in a touch more compression damping. Noticed that as standard the setting is only 3/4 turn out from max so not a lot to add. I've put on an extra 1/4 turn. Not sure it will make much difference. I will try tomorrow. Can anyone comment on the standard setting being nearly at max? Anyone made any changes?
i found the stock shock could not keep up with the rebound and, too, felt the wallowing and almost jacking, espeically when pushed hard. I put a Penske shock on and it really "cleaned" up the lack of rebound making the ride more compliant.
End of thread · 2 posts recovered Wayback Machine snapshot 11 May 2011
