[image: View Post]gll429, on 07 May 2011 - 12:03 PM, said:
[image: View Post]vfrgo, on 05 May 2011 - 08:20 PM, said:
hey all,
I'm considering re-jetting my stock carbs as I have a full TBR system with what probably will be a Delkevic can, on my 1993 VFR.
Im doing some research and hearing all kinds of stuff about both...
I'm a bit hesitant with the Dynojet stuff because you have to drill your carbs, and I'm not sure about that, but past that is there any other drawbacks?
that being said, what is the Factorypro stuff?
how would these two compare, in terms of performance.
I plan on running sotck air box, and stock filter unless otherwise suggested.
i'd love to hear some people who have some of these mods done on their 90-93. the good and bad, all welcome!
In the meantime I'm gonna go contemplate bike works over a cold one!
you didnt say WHAT YOU WANT!!!! if your going to run a stock filter your getting much if any gain from your exhaust pipe. ..aside from less weight. you need a better filter to get any gain from the jetkit.. however...
WHAT DO YOU WANT?? faster bike? better response? a bigger hit for passing power? smoother transition in speed? all can be done by playing with carbs and other stuff.
now remember.. you have to stop by my shop so i can take it for test ride and give you an expert opinion on how you did. :goofy:
well,
I had the exhaust only on the bike last season and it ran sort of fine... it Idled well, and it accelerated well, but it would pop on desceleration and it seemed like the bottom range (taking off from a stand still) was lacking compared to stock. Now, i did have exhaust leaks, as the old exhaust sytem doesn't fit well, and I haven't discovered muffler sealant stuff.. this year I'm better informed.
Also, while I was taking off my carbs, I've discovered that one of my carb insulators (boots, or the rubber things that connect the carb to the engine) had some imperfections (gouges of sort) running perpendicular to the groves that allow it to seal to the carb and engine. This in turn made that whole side of the engine mucked up with a fuel/road grime mix... It also, more importantly, probably means that some of my bikes sub par performance was due to one cylinder getting a less than optimal air/fuel mixture.
now keep in mind I haven't ridden any other VFR to compare my bike to, but from what I understand this bike should not be topping out at just over 200km/h (under 120mph), it should be passing that mark with relative ease. I havent found that to be the case.
So, as to what I want,
I want to get rid of the pop on downshifts, I wan to get a butter smooth idle (after a carb sync, that should take care of that), and I want to achieve that beautifull linear power delivery all the way up to over 10 000 rpm...
If by re-jetting I will get to this (which is what the DJ jets promise to do), and if I get a bit more power, that would be great!!
I don't really want to keep chopping parts on the bike, as bottom line is I trust the engineering of honda's engineers when they put this thing together more so than my guessing at how many holes I have to drill into an air box... or whatever....
I would prefer to do this with as little alterations to the stock parts as possible.
so a good combination of a aftermarket filter, or filter screen removed or whatever needs to be done to make the combination that I have (a well running 61 000km VFR, ceramic coated 2 bros headers, custom high mount midpipe with a Delkevic CF stubby can) work well is what I'm looking for.
I'm installing the DJ kit this weekend.
I think that I'll do it without drilling the slides, first, then check the bike performance (once the bike is back together) with stock filter and snorkel and all that, see what it's like on the street and highway, then if there is still more to be desired, I will deal with the air delivery system...
sorry for the lengthy response...
gll429 I may contact you today throughout the day as I progress with the DJ instal.
Nakedviffer and gll429 I'm intersted in what you both think would be the thing to do with the air box and air filter... what would give me most out of what I have with least amount of airbox mods....
thank you both !!!
really enjoying this 'healthy discussion' tween you two - and learning a few things along the way!
cheers,eh!
