VACUUM ROUTING DIAGRAM OR PIC
4 posts Started 8 May 2011 Last recovered post 8 May 2011 Wayback Machine snapshot 2 Jun 2011
Hey Guys,
Sweet Site!!! I'm Having A Problem Running The Vacuum Hoses For The Simple Fact That Who Ever Tried To Repair This Bike Before Knew Nothing About It, And Continued To Cut Vacuum Line And Tear Out The Vacuum Storage Tank (Which I Have Just Ordered Off ebay) Along With Broken Threaded Bolt Hole Tangs For The Coil Pack Mounts (Which I Also Ordered Off ebay) Left Front Shock Looks Like It Got Hit With A Hammer At The Top Of The Lower Fork Tube At The Top, Which Now Will Not Accept A Oil Seal. Also Trying To Figure Out If A 1984 VF1000F Interceptor Lower Fork Tubes Will Fit On This 1984 VF700F Interceptor. Any Info Would Be Greatly Appreciated!! I'll Post A Pic Of It Here For You.
Thor68372rockon :cool:
Attached thumbnail(s)
  • [image: Attached Image: 101_3103.JPG]
[image: View Post]Thor68372rockon, on 08 May 2011 - 06:24 AM, said:
I'm Having A Problem Running The Vacuum Hoses For The Simple Fact That Who Ever Tried To Repair This Bike Before Knew Nothing About It, And Continued To Cut Vacuum Line And Tear Out The Vacuum Stoage Tank (Which I Have Just Ordered Off ebay) Along With Broken Threaded Bolt Hole Tangs For The Coil Pack Mounts (Which I Also Ordered Off ebay) Left Front Shock Looks Like It Got Hit With A Hammer At The Top Of The Lower Fork Tube At The Top, Which Now Will Not Accept A Oil Seal. Also Trying To Figure Out If A 1984 VF1000F Interceptor Lower Fork Tubes Will Fit On This 1984 VF700F Interceptor. Any Info Would Be Greatly Appreciated!! I'll Post A Pic Of It Here For You.
There should be vacuum hose routing diagrams in the front section of the Honda Workshop Manual for your model. HTH.
(Interesting "title case" writing style you have there, mate...)
ITS HERE IF YOU NEED SOMETHING FOR VFR AND WELCOME !!!!!!!!!!!!!
Hey Thanx Guys I'll Check On Getting A Workshop Manual. Can Anybody Recommend A Good Low Cost Ultra sonic Carb Cleaning Kit. Don't Know A Lot About Them As I'm Old School On Cleaning Carbs, But Would Like To Give Them A Try.
End of thread · 4 posts recovered Wayback Machine snapshot 2 Jun 2011
