Unable to set sag on CBR 929 shock
[image: View Post]NakedViffer, on 14 June 2011 - 02:08 PM, said:
Quick fix would be to whip out the dremel and or file and sharpen up and re-shape that tooth on the end, it should grab if you do it right.There's nothing more to reshape. Both end pieces of the spanner wrench that anchor the collar for rotation have been deformed to the point that it's no longer grabbing. I think the metal used to make the spanner wrench is too soft and deforms too easily. Any applied torque ends up slipping. Is it suppose to be this hard to rotate the collar and set the sag on this type of rear shock?
[image: View Post]MBrane, on 14 June 2011 - 10:08 PM, said:
I bought one of these and modified it with my trusty grinder. Works much better than the cheezy shock wrenches they sell at most bike shops or the stock Honda wrenches, and cheaper too.Are you sure an oil filter wrench is going to work? I am willing to try any suggestion at this point.
Maybe that would help?
Good luck,
Ron
It works for me after grinding the extra grip from between the long end/handle, and thinning out the ends so they fit into the shock collar holes. It's a $5 tool so it's kinda hard to go wrong.
[image: View Post]ron_al, on 14 June 2011 - 10:25 PM, said:
I used to have a CBR900 shock on my Hawk GT. This may or may not help, but I found it easier to adjust the preload when it was on the centerstand (so that there was minimal load on the shock while I was trying to adjust it).Maybe that would help?
Good luck,
Ron
I've already tried that and it still would not budge. The soft oem spanner wrench eventually slips and eventually deform no longer usable.
Would it be possible to see a pix of the end product after all the grinding? I plan to pick one up and give it a try..
Give me a few to find my camera, and a trip to the garage......
I didn't grind off the teeth between the long end & the handle, but I did grind off 1 of the teeth on each end, and thin the ends out so they fit in the collar holes. You'll need to squeeze the handle pretty good, but if you do it won't slip or strip.
- [image: IMG_2931.JPG]
- [image: IMG_2930.JPG]
But I"d say you need to get some penetrating oil (not wd40) on the shock adjustment ring, that's not normal to be that hard to move, and let it soak in a few hours.
+1 being on the c-stand
Monk: Thanks for your suggestion about using penetrating oil.
You guys are awesome!!! :fing02:
[image: View Post]Monk, on 17 June 2011 - 11:14 AM, said:
So... How's about an update?I've was on a 5 day motorcycle tour through the California coast to Eureka and did not have time to do anything yet but will post an update when I get around to it.
What brand of penetrating oil do you recommend?
http://www.autozone....ier=597211_0_0_
[image: View Post]skymon, on 06 August 2011 - 05:00 AM, said:
Great tip Mbrane. Works better than brand new spanner tool. thanksI finally grind down the HF oil filter wrench as described by Mbrane and it works great. LIke skymon said, "Works better than bran new spanner tool." It only took me over a year.
Really doesn't seem like a year does it? Must be getting old. LOL Still using mine, and still working good.
