6th Gen Air Filter - building mountains out of molehills...
11 posts Started 10 Sep 2011 Last recovered post 16 Sep 2011 Wayback Machine snapshot 4 Aug 2012
Changing the air filter is a task that I had been procrastinating about for a while.
I probably wouldn't have procrastinated quite as much had I realized what was really involved.  Unfortunately there weren't any pictoral tutorials on VFRD to walk me through it.  So I grabbed my camera as I started the monumental task to document the entire process.   :comp13:
Having looked at directions of how to access the filter, I was a little reluctant to start.  First of all, it would require lifting the gas tank.
Now, in my mind the gas tank is a solid piece of metal, firmly attached to the bike.  It's not something you simply lift up.  It's not something that motorcycle manufacturers have ever intended to be lifted, tilted or removed in any way, shape or fashion - at least not in my mind.  Of course, this line of thinking had me envisioning smashed fingers if I lost my grip on the heavy, awkward tank, or problems lifting it up and holding it while attempting to fit a prop to support it. Since I had been warned about the importance of having an empty tank prior to starting, I assumed that the tank needed to be completely empty, and even as such it would prove a challenge.  (I'm sure you can guess where this build-up is going).
Trying to ensure that I had an empty tank was the first task.  Since I still needed to get myself and my bike home when I was running on fumes I stopped at a gas station for $2.19 worth of fuel.  I'm sure anyone who noticed the magnitude of my fill-up was amused.  The attendant in the store sure did - he even enquired over the intercom if I was having difficulty with the pump.  (No, not at all.  I always buy one point five litres of gas... it should be just enough to get me within walking distance of the NEXT gas station.)  By the time I arrived home my low gas light had been blinking for some time, and a quick calculation had me running circles around my area trying to burn off just a bit more fuel while still managing to ride the bike up the hill onto my driveway.  I didn't want to walk back to the gas station with Jerry Can in hand for another 25c worth of gas.  By the time I had the tank as close to empty as I thought I could safely get, it was late enough that shadows were lengthening.
Since it was obvious that daylight was waning, and I don't have the luxury of a garage, I parked the bike on the driveway and decided to wait for the following day. After all, this task was going to take three or four hours. The other warning I had been given about the air filter was to be careful not to drop any of the small screws holding the filter in place.  In my mind I was envisioning tiny screws the size of the ones holding my glasses together requiring the use of a precision screwdriver.  I was also picturing the area under the tank as having hundreds of small nooks and crannies where tiny screws with aspirations of freedom could secrete themselves.  Of course, small screws aren't simply limited to crevices in the bike to hide, I have an entire driveway with lots of places with hiding places for screws, bolts, washers, nuts... well, you get the picture.  Dusk with impending full dark does not make the best conditions to play a game of hunt and go seek for a dropped fastener.
Since I was envisioning worst case scenerios I had also questioned how much of a struggle removing the old air filter was going to be once I got to that point.  I figured that task would also likely involve broken fingernails and a blood sacrifice or two to wrestle the old filter out and coerce the new filter into a tightly fitting spot.
Have I mentioned that I have a highly active imagination well seasoned by weeks and weeks of procrastination and finding excuses to delay what was sure to be a memorable install?
By the time I had gotten to the task at hand, I had magnified it in my mind.  It wasn't going to be as simple or straightforward as an oil change.  But of course few things are.  Removing the mirrors from the bike last fall I illustrated my unique talent for complicating matters by stripping not one, not two, not three, but all four allen bolts, necessitating drilling out the original fasteners.  And perhaps it is best if we don't mention the fate of the late model power drills I was using to attempt to drill them out with.  I don't know what type of metal Honda used on the OEM bolts, but it certainly was soft in comparison to my allen keys simultaneously being hard enough to write off two ancient power drills - one that seized completely, and one that stripped an essential gear rendering it useless to drill anything more viscous than half melted butter.  With this in mind I walked outside, camera in one hand and new filter in the other ready for a task that could quite possibly take all day, or have my bike out of commission for a week or two.
After having turned a molehill into an entire mountain range I was ready to start the task.
It was deceptively simple, almost disappointingly so.  The tank was very light, and I could easily pick it up with one finger.  There were no crushed fingers.  There was no need for a power lift.  The screws on the air filter were large and easy to remove, although the front two were a little fiddly and I could see where a magnetic screwdriver would have come in handy. No screws were dropped, misplaced, stripped or mangled. None. The old air filter lifted right out, and the new one dropped straight in.  No blood sacrifice required.  I questioned if I had missed out on something - this was entirely too easy.   :laughing6-hehe:
Had I realized just how trivial and easy this actually was I wouldn't have procrastinated at all.
Difficulty: Exceedingly easy (embarrassingly so)
Time Required: Ten minutes (if you work at a slow, leisurely pace)
Pre-Prep: Ensure gas tank is mostly empty, down to the last one or two bars.  You don't need to worry about emptying the tank down to fumes.  Seriously, you could probably lift a half full tank without noticing the weight.
You need:
Socket Set with extension
Phillips screwdriver
Chain adjustment wrench and extension
Clean filter
You probably don't need:
Instructions
Photos
(But I will provide them anyhow... after all, it would have helped to have them to convince myself of just how easy the task was... besides, I had the camera prepared to document the entire process for you).
Lifting the Tank
1.  Remove the seat.
2.  Remove the two bolts at the front of the gas tank.  Each bolt has a washer associated with it.
[image: DSCF3585.JPG]
3.  Lift up the front of the tank and reinstall one of the bolts to use as a support for the tank prop.
4.  Tilt the tank back towards the rear of the bike, lifting it out of the way of the filter housing. There is a cord that will ensure you don't lift the tank too far.
5.  Clip together the chain adjustment wrench and extension and use it as a prop to hold up the tank.  If you put the open round end of the extension handle over top of the reinstalled tank mounting bolts it will not slip. (If you don't have the this tool, you can use almost anything to prop up the tank - it's not that heavy).
[image: DSCF3590.JPG]
Accessing the Filter
6.  Remove the screws holding the top of the plastic air filter housing.  There are seven Phillips screws holding it closed - two at the front, two on either side, and one at the rear.
[image: DSCF3592.JPG]
[image: DSCF3594.JPG]
7.  Lift up the filter housing and swing it out of the way exposing the filthy air filter.
[image: DSCF3596.JPG]
[image: DSCF3598.JPG]
8.  Lift out the dirty air filter.
My filter wasn't nearly as dirty as I had envisioned.  Quite honestly I wouldn't have been too surprised to find a mouse nest or two, but the mice around my house had apparently not discovered the joys of motorcycling. Not sure where the oil on the back of the dirty filter came from.  Your dirty pictures:
[image: DSCF3606.JPG]
[image: DSCF3610.JPG]
9.  Drop in the new air filter.
A few gratuitous shots of a clean air filter.
[image: DSCF3599.JPG]
[image: DSCF3600.JPG]
Reassemble the Bike
10.  Replace the air filter housing and refasten the phillips screws.
11.  Remove the prop holding the tank up, and remove the bolt you temporarily reinstalled to support the prop.
12.  Lower the tank and securely reinstall the bolts and washers at the front of the gas tank.
[image: DSCF3601.JPG]
Optional step: writeup a humourous tutorial about the buildup to pulling the bike apart and the simplicity of the maintenance.  Extra points if you make other members on VFRD laugh.
That's all there is to it.  It's that simple.   :fing02:
GOOD JOB and yeah VFR are hard on air filter  ....
The oil is mist coming from your crankcase vent hose. Perfectly normal.
Just be sure your oil level is not above the top fill mark in the sightglass with the bike on the centerstand and you're all set.
Ignore the oil mist. I just wipe it off whenever I have the airbox apart.
u forgot to remove the snorkle and disconnect the flapper valve before refitting the tank Posted Image
Olive,
In the future please state how long the job will take using 12 oz. beverages as the time unit  (e.g - This appears to be a two-beer job   :laughing6-hehe:   )
Rollin
Question....
How many male chauvinistic pigs does it take to change an air filter????
Answer....
None!!!
Let the woman do it herself.....
:laughing6-hehe:
Now,
as for changing a lightbulb.................................................
:owned:
[image: View Post]Dutchy, on 10 September 2011 - 07:00 AM, said:
Question....
Answer....
None!!!
:laughing6-hehe:
Now,
:owned:
Thank you Raymond!
BTW, How many people does it take to screw in a light bulb?
Answer: 2 but I have no idea how they get in there!
How many psychiatrists does it take to change a light bulb?
Answer: One but the light bulb must first want to change!
Etc, Etc. Etc.   :laughing6-hehe:    :beatdeadhorse:
[image: View Post]RollinAgain, on 10 September 2011 - 05:43 AM, said:
Olive,
Rollin
Nah, this is only a one-beer job--And that's assuming you drop at least one screw!
I wonder if I am at fault here, for often railing against how easy it is to drop those stupid screws I may have contributed to the perceived difficulty of this task.
I'm still gonna stand my ground and say a magnetic screwdriver and a little magnet on a stick are essential for this task!
Well done O, another job done by the crazy Canadian writing chick. BTW...i've changed em with just about full tanks, no issue just alittle extra weight lifting the tank. I say a 6-12 beer job, turn it into an alldayer and the wife will think you're a stud mechanic........
O, that'd make ya a Studette to the fella's.
Try swapping motors - once you've done that, changing the air filter is something you do with your eyes closed.    Man, the number of times I've had the airbox off my bike....
Great and very funny how-to, Olive!  Thanks for sharing it with us.   :smile:
My biggest fear is dropping one of the screws.  I got a magnet set from Sears a couple years ago to magnetize the screwdriver tip, and it works pretty well.  No sudden movements though, otherwise I think the dang screw would still drop off the end!
End of thread · 11 posts recovered Wayback Machine snapshot 4 Aug 2012
