So I purchased a set of HeliBars for my 2000 VFR and when I installed them the alignment hole for the left switch is in the wrong spot and points the switches too far down. Has anyone else run into this. I emailed them tonight after-hours and will hopefully get some resolution this week. Just curious if I'm the only one who has experienced this. Thanks Kags
Do you mean they're rolled from the top toward you ? Can you get the levers so the back of your hand is straight with your forearm ?
Anyway, The fix is to redrill the hole where you want it , which I'd like to do but haven't.............But I want them to roll more to me from the top, but I have a 6gen w/heli............
Pics added, The left switches are set in the alignment hole. They are rotated to far down by an amount that makes them unsafe.... For $280 bars, I would think they would makes this right and just send me a correct left bar....
