After getting as much info as needed, I started disassemble my 96er.
And here I am so far.
[image: index.php?app=gallery&module=images§ion=img_ctrl&img=577]
IMG 6381DURING DISASSEMBLE
Album: MODIFIES
Uploaded 04 Feb 2012 - 11:50
IMG 6410SPACERS FOR THE NEW R1 REAR SHOCK
Album: MODIFIES
May I suggest considering a smaller/lighter maybe kicked up rear subframe, maybe of aluminum, whiile you can, as the stock one hangs pretty low and big over the rear wheel, and weighs likd a boat anchor....
Looken good!
The R1 shock is sweet w/ low & high speed adjustment, but how much do you weigh?
The stock R1 spring rate is good for about a 90 lb rider, you'll need a major rate upgrade if you weigh more than a 100 lbs.
[image: View Post]Baileyrock, on 07 February 2012 - 07:13 PM, said:
Looken good!
My calculations are much lighter rider, but the point is the R1 shock needs a new spring and a revalve to work on the VFR. It's a good unit and properly setup would perform well.
I need to keep the subframe. This because of the "Thurn" rear fairing I've bought. However, I did made a new pair of risers and can't almost put my feet down to earth and I'm 185cm. :smile:
And about putting a new spring on the shock. I must first see how she rides, because "pimping" your bike doesn't come cheap.
I'm still waiting for the new headers and because of that, the mind is making overtime.
So here is what my mind made up so far.
[image: index.php?app=gallery&module=images§ion=img_ctrl&img=589]
Santa came early
Album: MODIFIES
Uploaded 25 Apr 2012 - 13:15
The Right Side
Album: MODIFIES
Uploaded 25 Apr 2012 - 13:14
[image: View Post]RCDekker, on 12 April 2012 - 03:42 AM, said:
Really??? Nobody??? What I do know is that my bike' s origin is found in Canada (MPH?) and made it to Holland (KM/H) Just a heads up Canada uses km/h not mp/h
That's why there is a questionmark behind it. But the headlight had a text on it that said it was from Canada.
So the lights came from Canada but the clocks could be US or UK (both MPH) though IIRC UK clocks would have MPH (primary) and KPH (secondary).
The clocks are in KPH and have always worked fine. However since I've been upgrading and put in a KOSO DB-01R
instead of the original clocks and meters. I discovered that the colours of the manual didn't match at all.
But after using the FLUKE I'm pretty sure I've done an OK job with the re-wiring.
There's only the fuel gauge that's going to be tricky. :unsure:
End of thread · 27 posts recoveredWayback Machine snapshot 24 May 2012
