Power Commander Maps Pres day map for Power Commander 5
1 posts Started 22 Feb 2012 Last recovered post 22 Feb 2012 Wayback Machine snapshot 16 Jun 2012
http://www.vfrdiscus...reenshot&id=162
File Name: Pres day map for Power Commander 5
File Submitter: VFRBenny
File Submitted: 20 Feb 2012
File Category: Power Commander Maps
This is a 6 speed map. This map has been evolving over the last few weeks. Speed Calibration was done via GPS and gear speeds were set @ 5k rpm.
Temps range from 50* to 70* but mostly in the mid 60's. Evevation was from Sea level to 4000 feet. Average around 1500 ft.
The trims are now at a max +/-1~3.
In mixed riding the MPG are @ 41. Tearing it up in the hill will get as bad as 36 mpg. Straight freeway speeds can get 43 mpg.
Most of the map is running 13.2 afr, But at 0~20% throttle in the 4250~6250 RPM range in 5&6 gears the AFR is 13.7.(I tried leaner, but the bike got back the mid range buzz, so 13.7 it is).
Y2K with gutted airbox, PiperCross filter, Staintune and no o2/Pair.
Enjoy.
Click here to download this file
End of thread · 1 posts recovered Wayback Machine snapshot 16 Jun 2012
