Fork Info Charts
7 posts Started 1 Mar 2012 Last recovered post 1 Mar 2012 Wayback Machine snapshot 30 May 2012
Does anybody know of a good fork length chart? I've been searching for days, and I've found just about everything BUT a full fork length chart
Here's a good one for fork Diameters:
http://www.zx6e.net/...showtopic=14121
http://www.soflaspor...swap-chart.html
Axle Diameters (Front and Rear):
http://www.clubchopp...-diameters.html
Steering Stem Bearing Sizes:
The TLzone Conversion Chart:
http://img.photobuck...ion-Details.jpg
Ohlins listing of replacement Fork Lengths:
Fork Conversion Bearings(REALLY GOOD ONE):
http://www.allballsr.../forkconvertion
and just a few other good ones:
http://www.caferacer...?TOPIC_ID=16794
http://www.triumphra...nts-thread.html
http://www.customfig...ead.php?t=53705
Thats all the research I've been doing this morning, I have found a number of GREAT sites, but not the one thing I've been looking for. I don't want to totally rely on the Ohlins replacement for lengths, because I don't know if they change the fork length for better performance, and that list isn't all that complete anyways! so is there ANYONE at all, who knows of a good list of USD fork lengths?
I am trying to get together some fork legs to do a swap on my new 5th generation, I have a little machine shop in my basement, so my only concern is finding nice fork legs, everything else I can modify/make to fit the bike.
-Matthew
Good stuff, thanks for the resource links! :smile:
I have some in print at home, one came from the GSXR forms and shows all numbers for about a dozen sport bike forks.
If I can scan the info I'll post up. :ph34r:
I have a decent spreadsheet going at home. However, a lot of it came from the Internet so I've been verifying & updating the numbers as needed, as I come across them.
Take everything you see with a grain of salt unless you really trust the source. I'll try to remember to post the sheet here later.
Those are great resources for front end projects......What about adding in a (link?) chart for proper rear shock eye to eye legnths for all the VFR generaions?
Beck
95 VFR
That would be awesome if you two could post those up! I have been trying to find a nice USD fork with Radial Calipers of the right length for a couple days with absolutely no luck at all, I know that the R1 is a pretty common swap, but based on looking at the numbers, it looks like it would be wayyyyy short! not that I would know from experience what too short is, just trying to stay in the same ballpark as the stock 5th generation.
I read somewhere on this forum about the 5th generation forks being a little weak and can cause a terrible wobble in a hard turn, so I was really hoping to get info on some of the larger diameter forks, such as the 2003 ZX-6r forks, 2003 Yamaha R6 forks?
Beck
95 VFR
I wouldn't know where to begin with that, but I'm sure if it's a common thing to look up, members would appreciate it! just start googling!
So I just realized that all of the fork diameters on the first chart/link I posted, are on bikes 2004 or older, nothing newer, which really limits my options for finding USD forks with radial calipers, that would also be great information if anyone has it!
End of thread · 7 posts recovered Wayback Machine snapshot 30 May 2012
